Author Topic: pcie wifi antennekabel replacement  (Read 5511 times)
Offline eentje
« on: September 18, 2015, 06:38:39 PM »
like the topic Says. is it possible to buy just the antenna of the pcie wifi kit. i have seem to misplaced mine and cant find it anymore. i hope i can just find entire kits for like 40 euro. and that is a bit a waste of money since the most expensive part of the kit is the card itself and not the antenna.
i hope amoderator or a med employee can point me in the right direction preferreable with a link
www.thetvdb.com contributor
Offline Nachoman
  • Helpful Contribution Status: +2/-6
Re: pcie wifi antennekabel replacement
« Reply #1 on: September 19, 2015, 12:02:30 AM »
Like the way u spelled "antennekabel" think it was antenna cable. Lol. i think your dutch.
check this u cheap hollander :P
https://www.update.nl/nl/142701/tp-link-wireless-n-150mbps-pci-express-adapter/
Man will never be free until the last king is strangled with the entrails of the last priest. Denis Diderot
Offline eentje
« Reply #2 on: September 20, 2015, 04:48:43 PM »
Thx for the link
