Author Topic: Autoplay functionality on MED250X  (Read 7204 times)
  • Helpful Contribution Status: +114/-28
« on: September 02, 2015, 02:29:46 PM »
AUTOPLAY
Mede8er allows for automated folder play when the Mede8er is switched on. The autoplay facility is very useful and can turn the Mede8er into a very effective low cost Digital Signage Solution.
Autoplay Function
The Autoplay files can be stored on SD Card or USB Drive.
1. Create a folder in the root of the drive named “Autoplay” (Case Sensitive)
2. Put either Video OR Audio files into this folder
3. If you require the files to play in order name them as following 01name - 02name - 03name - 04name - 05name - 06name - 07name - 08name - 09name - 10name - 11name up
Autoplay Operation
On power up the Mede8er will look for the “Autoplay” folder and if found it will automatically play the contents of the “autoplay” folder. The contents will be played with the “Repeat All” as default. If a USB Drive is plugged into the Mede8er it will auto scan for the “Autoplay” folder and if found it will start the Autoplay function.
