Author Topic: Glitches at scene changes on 3D MKV movies...Disney's Tangled  (Read 11458 times)
Offline Larry56
« on: August 24, 2015, 07:42:43 AM »
I wish they'd fixed those glitches (flashes of pixelation) I've seen and have heard others complain about at scene changes. It happens only during 3D movies and Tangled is a very good example. At every scene change, these pixelated blocks appear for a half second. Please fix this in the next firmware please. Thanks.
Re: Glitches at scene changes on 3D MKV movies...Disney's Tangled
« Reply #1 on: August 24, 2015, 09:41:11 AM »
It cant be fixed. Its a consequence of having to use avchd 2.0 camcorder code.  You can remux to a single stream using makemkv.
A licence for full blown bd playback only covers using real disks from an optical disk player. If disk authoring on some disks creates issue, then that licence covers fixing it. So some bd players have needed upgraded firmware to play tangled. The camcorder licence cannot cover making changes to fix doing something classed as not covered by the licence, that is playing bd rips. It is only supported by accident.
The issue covers any disk using angle, such as splicing in extra scenes to create the directors cut out of the theatrical.
Many modern disks seem to do it when its not needed, to make rip playing under current licenes unpleasent.
« Last Edit: August 24, 2015, 11:44:20 AM by jer1956 »
Offline TifKag
  • X2 Skin Designer
« Reply #2 on: August 24, 2015, 01:07:42 PM »
Just like jer1956 said bring it back to a SBS or TAB stream with Makemkv (Without compression)
I have just tested my SBS version, and no pixelation at all
Offline Larry56
« Reply #3 on: August 24, 2015, 07:01:10 PM »
I bought the retail blu-ray and used and converted the file (without compression) to an MKV file, using MakeMKV. I didn't use SBS or TAB because, AFIK, MakeMKV doesn't have that option. Is that option there and I'm missing it?
I just did a straight to mkv conversion (no compression) and checked "Mpeg4-MVC-3D" in MakeMKV, then added ".mvc.mkv" in my file extension for the Mede8er. I could try using DVDFab to convert it to SBS. Are you saying this is the fix?
Offline Pasiocave
« Reply #4 on: January 14, 2019, 07:52:27 AM »
I also have problems using it as well.
