Author Topic: Med250X - Unknown hardware error  (Read 1564 times)
Offline Kismet
« on: August 24, 2015, 06:33:38 am »
Hi there
I have had my 250x a while now and this error recently appeared:
"unknown hardware , cannot read software"
I installed the firmware and the error is still displayed on my TV.
Please help
  • Helpful Contribution Status: +100/-24
Re: Med250X - Unknown hardware error
« Reply #1 on: August 24, 2015, 06:56:54 am »
Pls try install this firmware and it should fix the 'unknown hardware' problem
https://www.dropbox.com/s/1kbac3i01h7hy5o/MED250X_V1.6S_Europe.zip?dl=0
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button on the Mede8er (not the remote) and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
