Author Topic: Feedback for - V4.0.2 - 29July2015 -X3D Series  (Read 30757 times)
Offline PTDennis
Re: Feedback for - V4.0.2 - 29July2015 -X3D Series (beta)
« Reply #30 on: August 12, 2015, 11:14:27 am »
Thank you for keeping us up to date and for working on the trailers issue!
  • Helpful Contribution Status: +190/-53
« Reply #31 on: August 12, 2015, 08:06:27 pm »
We know changing the trailer scanner is just a question of effort by the engineers. But its wasted effort if we can't autoplay the trailer. We are keeping in contact with trailer addicts so that they appreciate how keenly we need that added. In the mean time we mods are looking at ways to auto push the play button in our own time.
« Last Edit: August 12, 2015, 08:40:38 pm by jer1956 »
Offline explore
My Shortcut passwords are shown and not as ********
« Reply #32 on: August 13, 2015, 07:47:39 pm »
I  bought the 1000X3D a few weeks ago. Am using firmware v4.02Beta.
At Media Library>Network>My_Shortcuts, when I choose to edit my shortcut, the popup window displays my password instead of it being ******. I hope this is not intentional but a bug. Else anyone can see my password and gain access to my network. Thanks.
Re: My Shortcut passwords are shown and not as ********
« Reply #33 on: August 13, 2015, 08:49:40 pm »
How can  anyonwe run the gui remotely via the network, never mind the internet?
Offline explore
« Reply #34 on: August 13, 2015, 10:05:40 pm »
Thank you for your quick reply.
I agree with what you wrote.
I realised "gain access to my network" was a poor choice of words. Instead I should hv written "gain access to my PC shared folders".
I hv given my WiFi password to some friends and relatives so that they can hv internet access while at my place. I'm concern that with the login/password they can see in the Mede8er. Does it not mean they can access my PC shared folders from their laptops and smartphones. I dont mind them watching the videos from Mede8er but do not want them to be able to copy to their laptops and smartphones.
I'm not well knowledge in networking. Just know basic sharing that's all.
« Last Edit: August 13, 2015, 10:45:15 pm by explore »
« Reply #35 on: August 14, 2015, 07:11:20 am »
So your guests have both access to using the players gui, and to your network via wi-fi?
It is a very niche secuity issue, but yes they could use the shortcut information to connect directly to password protected shares.
You would have to post that you need a solution as a feature request.
In the mean time change your pc share password whilst guests are in the house.
Offline SleenT
« Reply #36 on: August 17, 2015, 05:52:29 pm »
When will we see support for the H265 codec?
Offline marinero
« Reply #37 on: August 17, 2015, 07:40:52 pm »
next week.............
Offline APMichael
« Reply #38 on: August 18, 2015, 09:20:56 am »
Never, because the chip set (RTD1186) doesn't support this new codec. It's not possible to add a new "hardware codec".
Mede8er MED600X3D (V4.0.2-7Nov2015), Denon AVR-2310
Offline adi1
  • Helpful Contribution Status: +0/-4
« Reply #39 on: August 19, 2015, 05:31:35 pm »
I Have a big request.
Is it possible to create subtitles with black box background.
example
http://captionmax.com/structure/img/blog/subtitles_black_box.jpg
Offline sitthichaikk
« Reply #40 on: August 22, 2015, 06:43:24 am »
After upgrade FW on my MED800X3D from 4.01 to 4.02. also I been restore default one time then  I found my connection through WIFI not working any more as step below..
1. turn on PCIe WIFI.
2. turn on Wireless then the player show my SSID.
3. I choose my WIFI name then the player show to selected as WEP(HEX) or WEP(ASCII) .......I choose WEP(HEX) then put correct pwd.
(if I select WEP(ASCII) after put my pwd will reboot the player.....It's going worst)
4 the play show testing for a while then the result as "Test failed"
Any suggestions???
Offline explore
« Reply #41 on: August 22, 2015, 07:24:59 am »
Thanks for the suggestion. I'll give it a try but its not that big an issue. What I would really like to see is thicker black outline for the subtitles. I really like my new 1000X3D a lot. In so many ways it surpasses my old Xtreamer Prodigy except the Prodigy has really thick subtitles outline which makes reading really easy. I'll attach a picture. I really hope the 1000X3D will have such thick outlines because to me its the only area the Prodigy is better.
Offline Crrispy
« Reply #42 on: August 24, 2015, 12:49:34 pm »
HI,
Not only the trailer function does not work anymore but you can't even exit the video search, had to do a hard power off with the power button (not the remote).
« Reply #43 on: August 24, 2015, 01:01:23 pm »
HI,
Any activity which results in a hung internet transfer hangs the player. It can't multithread an error handling routine.
Offline explore
« Reply #44 on: August 24, 2015, 04:50:33 pm »
Just added picture of same scene with 1000X3D subtitles outline for comparison.
