Author Topic: 3D mkv shuttering  (Read 2360 times)
Offline nappis
3D mkv shuttering
« on: July 06, 2015, 01:45:33 PM »
Hi!
I have MED600x3D, cat 6 cables, HP N54L nas and D-link gigabit switch.
The problems is with 3D files. After 10 minutes watching it starts shuttering. Audio disappears and picture stops to few second. After that it continues normally some minutes and repeats it.
I have tried same file directly from usb drive with Mede8er and there's no problems. It plays just fine.
Edit: Forgot to mention, router is of course with gigabit ports.
From router it goes to switch. Mede8er, nas and pc have connected to switch. Copying from pc to nas or other way is goin about 70MB/s.
Mede8er have the latest beta firmware.
« Last Edit: July 06, 2015, 03:12:58 PM by nappis »
Offline Bytec
Re: 3D mkv shuttering
« Reply #1 on: July 06, 2015, 03:10:43 PM »
Try using NFS instead of SMB.
That solved my problem with high bitrate 3D MKV files remuxed from Blu-ray.
MED1000X3D -> DENON AVR 1611B -> SAMSUNG Plasma TV PS64F8500
Offline nappis
« Reply #2 on: July 06, 2015, 03:13:55 PM »
I'm using NFS
Offline Fmedrano1977
Re:
« Reply #3 on: July 06, 2015, 04:15:58 PM »
No issue here with NFS and full bit rate mvc mkv rips.
Sent from my HTC One M9 using Tapatalk
Offline mr.tyler-durden
« Reply #4 on: August 13, 2015, 06:46:02 AM »
How did you merge the MVC mkv? Does this happen with every mkv you have? Have you tried to open an ISO with Full3D - ssif data (you have to disable BD-lite menu in settings)?
MED: 1000X3D - V4.0.1 (April beta)
A/V:   Onkyo TX-NR616 (7.1 setup)
TV:    Sony KDL-55W905
NAS:  Synology DS414 (4x4TB)
