Author Topic: MED600X3D: "Logon fail" reported when using Samba share with Windows 7 server  (Read 10425 times)
Offline APMichael
The problem has returned. Logon fail :( Windows 10...
Maybe it's caused by a disabled SMB1 server:
http://www.mede8erforum.com/index.php/topic,19348.msg115858.html#msg115858
Mede8er MED600X3D (V4.0.2-6April2016-p2), Denon AVR-2310
  • Helpful Contribution Status: +105/-27
Offline Sierra
Re: MED600X3D: "Logon fail" reported when using Samba share with Windows 7 server
« Reply #32 on: September 03, 2018, 11:33:13 am »
Thank you for your reply, it basicaly worked, I have one issue however, I cannot jump to desired moment of a video, when I press right arrow on the remote, and pick let's say 30min of given movie it not allowing me to. All I see it "X". So basicaly I can only play, pause or stop and thats it. Is there a solution to this?
Offline Sierra
« Reply #33 on: September 03, 2018, 11:49:23 am »
Bingo! That was it. Now I have access again. Thank you!
Offline APMichael
« Reply #34 on: September 03, 2018, 11:58:58 am »
Great! I'm glad I was able to help. :)
Offline gloriouss
    • เสื้อฮาวาย วินเทจ
« Reply #35 on: September 07, 2018, 05:14:36 am »
I think it usually happens more often if I've done some file managing
