Author Topic: different movie walls  (Read 2160 times)
Offline beamer64
« on: June 21, 2015, 10:23:12 am »
Hi all,
I just got my med 800x3d and using Yadis. I have created a moviewall for my daughter movies located on a seperate folder.
Now  I am trying to make an other moviewall for my movies. I made an other output file for my movies, but that does't work in yadis2mede8er. Can this be done in Yadis?
Thanks you for your help.
Offline Fmedrano1977
Re:
« Reply #1 on: June 21, 2015, 01:29:27 pm »
Movie wall? If you are trying to keep the folders separate, just add the folders to favorites/scan them and the jukebox view will only display movies in the folder selected. As far as YAMJ or Yadis, on both, everything scraped gets cached in one folder.
Sent from my HTC One M9 using Tapatalk
Offline beamer64
Re: different movie walls
« Reply #2 on: June 21, 2015, 01:45:46 pm »
Thanks for your input, I thought that  the movies would all show up in one jukebox if I ran them through yadis rather then seperated. I appreciate your help.
