Author Topic: Crackling Sound with 5.1 FLAC on MED600X3D  (Read 1756 times)
Offline DR3AMMA5TER
« on: May 06, 2015, 07:40:21 pm »
Hi there,
I have the MED600X3D and i'm very happy with it BUT when i play 5.1 FLAC files there is a annoying crackling/stuttering in the sound and it only happens with 5.1 FLAC files, 5.1 WAV files plays perfect!
I tried different FLAC files with different bitrate and sampling rate/bit depth but it always occurs.
Does anyone has an solution for this? because it's very annoying.
below some media info from a 5.1 FLAC with the crackling sound:
General
Complete name               : E:\Downloads\Supertramp - Crime of the Century (2496 51 FLAC's)\05.Dreamer.flac
Format                      : FLAC
Format/Info                 : Free Lossless Audio Codec
File size                   : 199 MiB
Duration                    : 3mn 33s
Overall bit rate mode       : Variable
Overall bit rate            : 7 836 Kbps
VALID_BITS                  : 24
HDCD                        : 0
Audio
Format                      : FLAC
Duration                    : 3mn 33s
Bit rate mode               : Variable
Bit rate                    : 7 836 Kbps
Channel(s)                  : 6 channels
Sampling rate               : 96.0 KHz
Bit depth                   : 24 bits
Stream size                 : 199 MiB (100%)
Writing library             : libFLAC 1.2.1 (UTC 2007-09-17)
