Author Topic: Dutch Thumbgen Template for Mede8er  (Read 9349 times)
Offline DR3AMMA5TER
« on: May 03, 2015, 12:50:03 am »
Hi there,
I edited the default Thumbgen Template for use on my Mede8er in Dutch language.
I thought maybe someone will appreciate it.
below is a sample how it looks like.
The template can be downloaded here:
http://www.mediafire.com/download/zgsnawk6uvf8p6w/_Mede8er_Dutch_ThumbGen_Template_.rar
Offline wirusek
Re: Dutch Thumbgen Template for Mede8er
« Reply #1 on: May 06, 2015, 08:36:07 am »
what should I do to have a visible icon from the bottom of the image (for instance HD1080, matroska ...) on my x800?
Offline DR3AMMA5TER
Re:
« Reply #2 on: May 06, 2015, 10:29:22 pm »
I don't understand  your question.
Do you mean a folder. jpg icon so you can see the movie covers?
Offline DR3AMMA5TER
Re:
« Reply #3 on: May 06, 2015, 10:32:27 pm »
Oh you Mean you want to change the movie sheet so the icons are at the bottom.
You can change the default template with thumbgen designer,  it's pretty simple.
Offline wirusek
« Reply #4 on: May 07, 2015, 05:30:26 am »
I have an additional program ? Now I am doing everything through wifi in mede8er .
Offline DR3AMMA5TER
Re:
« Reply #5 on: May 07, 2015, 08:45:20 am »
Yes this template is for use with thumbgen as you can read in the title...
Offline razserv2010
« Reply #6 on: July 28, 2017, 08:23:51 am »
how do i install that?
Offline razserv2010
« Reply #7 on: July 31, 2017, 11:56:25 am »
« Reply #8 on: July 31, 2017, 04:02:48 pm »
It is for those who use thumbgen as an external scraper.
http://www.mede8erforum.com/index.php/topic,7114.0.html
Offline razserv2010
« Reply #9 on: July 31, 2017, 10:28:45 pm »
Thanks a lot friend!
