Author Topic: V3.0.5 - 26 April 2015 Beta for ME500X2, MED450X2/S, MED400X2/S  (Read 33570 times)
  • Helpful Contribution Status: +94/-20
Hi All X2 Users
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc  Those who have not used 2.1.1 must do  this. The code only adds Volume Names to virgin  drives when they are formatted.
Vanishing files and un-mountable partitions can occur as  a result of using Safe Removal.
Download X2 Series - V3.0.5 - 26April2015
http://www.mede8er.org/beta/Firmwares_Beta/X2_Series/X2_Series_V3.0.5_23April2015_BETA.zip
Changelog V3.0.5 - 26April2015
1. Fixed the Weather App - City selection images still showing once selected
Changelog V3.0.5 - 22Oct2014
1. Fixed. incorrect background 'Safely Remove Hardware' on Devices Screen
2. Changed Dutch translation Misc ---> Diverse
Changelog  V3.0.5  - 20Oct2014
1. Fixed - TV Series 'EDIT' slow Navigation
2. Fixed - Thumbnail focus in 3 row Movie JukeBox when navigating to new page
3. Added Portuguese GUI language
Changelog  V3.0.5  - 12Oct2014
1. Improved default GUI navigation speed and updated default background image.
2. Fixed problem that local trailer plays by default from Movie JukeBox and users cannot play the actual movie - ignore 'movie.name.trailer.*' for users with X2 and X3D series who use local trailers.
Changelog  V3.0.4  - 22May 2014
1. Fixed Shoutcast Internet Radio
Changelog  V3.0.3  - 13May 2014
1. Fixed - Scraping Agreement Page remaining after accepting the terms when doing a EDIT first time after install
Changelog  V3.0.3 BETA  - 12May 2014
9. Dev. allow about.jpg EDIT directly after firmware update - old way you had to do a 'Scan' first in order to see the Agreement  Page.
Movie Scraper Skin 'A'
New TV Series Skin
Online Movie Scraper Guide
Online Jukebox+ Guide
JukeBox Plus
JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files. Do not set the favourite link to  an actual jukebox as the jukebox+. Using jukebox+ Reset may then delete your media!
If you  find your self in this position, remove/disconnect the host store for the jukebox+, and then perform a Reset Jukebox+. That might require you shutdown first and remove drives, lan  cables etc.   After doing the reset, shutdown again, are reconnect the removed storage.  Favourites will now show "all"  the links including a working jukebox+,  but the Menu  now has the Aggregate Jukebox option to  create the dummy you should have in the first place.  Until you  do  that, Add to Jukebox+ won't appear again. You can then  turn the wrongly used folder back to  a media store.
JukeBox Plus Instructions
3. We have added a facility in the GUI to add a folder so you do not require a PC to do this -   Navigate to a Drive or Network Share in the Mede8er Media Library and press the 'Edit' button on the remote and you will see a new function named 'New Folder'  - Use this this make your JukeBox Plus folder
WOL (Wake On LAN)   Setup Menu ---Misc  --- WOL
Select the devices you want X2 to wake up on boot - WOL on X2 boot-up is not always reliable due to the  network not always being ready so X2 will also send the Magic Packets when you enter the Favourite Screen. You can also do a manual WOL in Setup Menu - focus on Device and press 'F1 /Red' button.
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X2. Plug the power jack back in and then hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
Remove any USB drives and /or  Mede2key dongle before performing the upgrade.
