Author Topic: yadis 2.3 vs Windows 7 vs dune base 3d HD  (Read 7477 times)
Offline cemalptekin
« on: February 28, 2015, 10:58:48 am »
any idea why this happens?
« Last Edit: March 01, 2015, 10:47:22 am by jer1956 »
Re: yadis 2.3 vs Windows 7 vs dune base 3d HD
« Reply #1 on: March 01, 2015, 10:51:00 am »
Please use Attach for  small images. See Additional Options.  If you must use a free hosting site please use one without links and pop-ups to  sites which  break  the forum posting rules.
Offline mikek
« Reply #2 on: March 10, 2015, 10:42:48 pm »
It looks like the fonts are too big in the template you are using.
Try a different template.
Offline Mr Eric
« Reply #3 on: March 12, 2015, 03:58:12 pm »
that's not the template...
You are using >100% windows fonts. Check your windows properties and go back to 100% fonts. then reprocess all your movies in yadis so the text will be correctly displayed.
Yadis beta team member
Offline matchorno
« Reply #4 on: June 21, 2015, 01:44:02 am »
It's probably dpi on your computer.  I have mine set to 125% so i can keep my resolution fairly high, but also see everything a little better/bigger.  However, i wouldn't worry about the way it looks on your monitor.  If it truly is your dpi, then it won't be an issue on your med8er -> TV.  Because however it looks on your p.c., does not mean it will look like that on your tv.
Offline matchorno
« Reply #5 on: June 21, 2015, 01:45:11 am »
BTW...what does the title of this post have to do with the question/content?
Offline Mr Eric
« Reply #6 on: June 26, 2015, 10:36:58 am »
this will impact the output file from yadis. So you need to use 100% fonts. This preview window from yadis is WYSIWYG ;)
