Author Topic: NFS Problem with Synology DS215j and x600  (Read 21388 times)
Offline benton18
« on: February 10, 2015, 10:53:53 PM »
Hi!
I followed the tutorial, to activate NFS, and finaly, i see the share with the correct IP of the NAS, but when i try to open it, Mede8er says, failed. He doesn't ask me to enter my user and password or something.
In the NAS, i enabled my user with the correct privilegs, but now, i don't know how to go on.
thanks for any help
greets
Sony 55W905
Re: NFS Problem with Synology DS215j and x600
« Reply #1 on: February 11, 2015, 12:00:15 AM »
Check your synology network config settings and be sure that you did not enable jumbo frames.
Use MTU default setting = 1500
Als reboot your mede8er after changing that, and then goto Media Library, goto NFS
Offline benton18
« Reply #2 on: February 11, 2015, 12:00:27 AM »
by the way, i used to play my files from a windows pc with Hanewin NFS server before, this works fine for me with untouched bd 3d images. that is why i have to use NFS cause it stutters with SMB
Sony 55W905
Offline benton18
« Reply #3 on: February 11, 2015, 01:02:55 AM »
jumbo frames are disabled, MTU =1500, that says my synology.
Sony 55W905
« Reply #4 on: February 11, 2015, 06:23:10 PM »
Check the NFS rights you have set on your synology shares.
You should have set the rigth IP number of your mede8er or the whole subnet with a * and read/write access for that IP number.
