FYI, I've updated my 800X3D to version 4.0.0. I have a folder that was added to Favorites and it's a aggregate jukebox. The Jukebox View is ON in the settings menu.
Typically when I add a new movie (.iso in it's own folder), I go to the directory that contains the movie folder via the Media Library. I then highlight the folder and press the Menu button, then select "Scan Folder" and it adds all the meta data.
If I recall correctly, I would then press the Menu button again over the same directory and press "Add to Jukebox".
Well, "Add to Jukebox:" is not listed.
Can anyone help? Did something change from the firmware update?
