Author Topic: Feedback for - V3.0.7 - 30Dec2014 BETA -X3D Series  (Read 15444 times)
« on: December 29, 2014, 09:29:32 PM »
Offline yellow puma
Re: Feedback for - V3.0.7 - 30Dec2014 BETA -X3D Series
« Reply #1 on: December 29, 2014, 10:07:27 PM »
Hi i tried to load the new firmware with the emergency procedure but apparently i was not successful. Does this apply for the 600x3D? I now have v2.0 and the new boot loader.
« Reply #2 on: December 29, 2014, 10:15:40 PM »
Yes, this should work on a 600X3D.
In setup check if you have BOOTLOADER VERSION KIIE.0402.0065
If yes, STEP2
Install V3.0.7 - 30Dec2014Beta
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2014/X3D_Series_V3.0.7_BETA_30Dec_2014.zip
Use Emergency installation procedure:
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and then hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
Offline yellow puma
« Reply #3 on: December 29, 2014, 10:56:25 PM »
Finally it worked but in the other USB port of the MED. Thank you very much!!!!
I would not realised that changing USB port would do the job.
Now i am fully updated and can explore the new features.
Offline wajs
  • Helpful Contribution Status: +3/-1
« Reply #4 on: December 30, 2014, 09:34:51 AM »
Polish translation:
Układ informacji o filmie
Domyślne napisy (Internal: Z filmu, External: Z pliku)
Poprawienie głośności
Dodaj zwiastun
Kolor ramki miniaturki
Wyczyść
« Last Edit: December 30, 2014, 01:42:56 PM by wajs »
Offline Fan234
« Reply #5 on: December 30, 2014, 11:14:14 PM »
Although this version is not too bad it still does what the previous beta did with my movies.
I play a movie and periodically the movie freezes. If I wait (non specific) some time the movie starts again. In this beta it is maybe once or twice a movie. In the previous beta (3/12) it happened up to 10 or 12 times per movie.
This happens on all movies that have previously played flawlessly.
Offline wajs
« Reply #6 on: December 31, 2014, 09:52:42 AM »
Auto Standby does not work.
If the folder is the one movie - auto standby does work,
If the folder is the several (3) movies - auto standby does not work,
(Do not press "STOP", play first movie and wait)
« Reply #7 on: December 31, 2014, 10:07:24 AM »
You should repost in Tech Issues, with far more details .
Offline frizera
« Reply #8 on: December 31, 2014, 03:18:33 PM »
I want to report a problem. Has existed for a long time,meaningless from firmware version.  Independently of updates the problem still exist. When i looking at the posters only on the jukebox, player restarts alone without any reason. Thanks for the great work in the past year and wish you health, luck and prosperity to all the team who cares our players are at a high level. Many thanks and Happy New Year to all !!! Cheers!
"If it's stupid but works, then it is not stupid"
« Reply #9 on: December 31, 2014, 03:37:25 PM »
Do  you have Trailers set to ON?  See what happens if you  put that to Off.  Abouts are now "dynamic", in thse sense that the XML has to  be checked and the Trailer Controls Overlay put on top.
Or do  you mean browsing icons on the movie selection GUI?
Offline frizera
« Reply #10 on: December 31, 2014, 03:54:30 PM »
Yes, only wen i browsing on movie selection. I never turn on the movie trailer option. This problem there is more than version 3.0.6. Source is home server. I dont have drive into the player.
« Reply #11 on: December 31, 2014, 04:00:05 PM »
So it crashes when  you  change highlighted icon, or have to change a complete page?
Offline frizera
« Reply #12 on: December 31, 2014, 04:52:56 PM »
I not change anything.
« Reply #13 on: December 31, 2014, 05:02:16 PM »
So it opens  the first page of jukebox, and crashes?
Offline frizera
« Reply #14 on: December 31, 2014, 07:22:03 PM »
No.Restart occurs only when i looking at the covers of movies.
