Author Topic: Movie Scraper Skin Packs for V3.0.7 25Dec or later  (Read 27483 times)
« on: December 26, 2014, 06:38:13 PM »
Also FIRST update your Mede8er to V3.0.7 25Dec or higher otherwise this Skinpack will not function properly.
How to change a skin:
If you using a 'Community Skin' then you must just copy the 'scraper' folder including its content into 'Community Skin' folder.
Download X3 Yadis Look Movie Scraper Skin Type B
NOTE: This Scraper skin will only work correctly with firmware V3.0.7 25Dec or later. In Setup goto Misc --> Scrape Layout and select Type B. If you use the 'EDIT' function and 'Save' you may notice some movie poster images have some noise at the top - to fix just scrape them again and the noise will be removed.
« Last Edit: December 28, 2014, 05:16:28 PM by Mede8er1 »
Re: Movie Scraper Skin Packs for V3.0.7 25Dec or later
« Reply #1 on: December 27, 2014, 03:50:19 PM »
Download X3 Eclipse Movie Scraper Skin Type C
NOTE: This Scraper skin will only work correctly with firmware V3.0.7 25Dec or later. In Setup goto Misc --> Scrape Layout and select Type C. If you use the 'EDIT' function and 'Save' you may notice some movie poster images have some noise at the top - to fix just scrape them again and the noise will be removed.
Mede8er Eclipse Movie Scraper Skin
Full Size Image
http://www.mede8er.org/artwork/temp/2014/Forum/Movie_Scraper_Skin_Eclipse.jpg
« Last Edit: December 28, 2014, 05:16:42 PM by Mede8er1 »
« Reply #2 on: December 28, 2014, 05:05:33 AM »
Download X3 Eclipse Movie Scraper Skin Single Cover Type C
Mede8er Eclipse Movie Scraper Skin Single Cover
Full Size Image
http://www.mede8er.org/artwork/temp/2014/Forum/X3D_Eclipse_Movie_Scraper_Skin_Single_Cover.jpg
« Last Edit: December 28, 2014, 05:16:52 PM by Mede8er1 »
« Reply #3 on: December 28, 2014, 08:45:16 AM »
Download X3 BD Cover Movie Scraper Skin Type C
Mede8er BD Cover Movie Scraper Skin
Full Size Image
http://www.mede8er.org/artwork/temp/2014/Forum/X3D_BD_Cover_Movie_Skin_Type_C.jpg
« Last Edit: December 28, 2014, 05:17:10 PM by Mede8er1 »
« Reply #4 on: December 28, 2014, 12:54:37 PM »
Download X3 BD Cover Movie Scraper Skin Alternate  Type C
Mede8er BD Cover Movie Scraper Skin Alternative
Full Size Image
http://www.mede8er.org/artwork/temp/2014/Forum/X3D_BD_Cover_Movie_Skin_Type_C_Alernative.jpg
« Last Edit: December 28, 2014, 05:17:34 PM by Mede8er1 »
« Reply #5 on: January 05, 2015, 07:28:26 PM »
Also FIRST update your Mede8er to V4.0.0 - 2Jan or higher otherwise this Skinpack will not function properly.
Download X3 Metal Frame Movie Scraper Skin Type C
NOTE: This Scraper skin will only work correctly with firmware V4.0.2 - 2Jan or later. In Setup goto Misc --> Scrape Layout and select Type C. If you use the 'EDIT' function and 'Save' you may notice some movie poster images have some noise at the top - to fix just scrape them again and the noise will be removed.
Mede8er Metal Frame Movie Scraper Skin
Full Size Image
http://www.mede8er.org/artwork/temp/2015/X3D_Movie_Meta_Frame_Scraper_Skin.jpg
