Author Topic: Feedback for - V3.0.7 - 25Dec2014 BETA -X3D Series  (Read 16558 times)
« on: December 25, 2014, 06:41:02 PM »
Offline inikad
Re: Feedback for - V3.0.7 - 25Dec2014 BETA -X3D Series
« Reply #1 on: December 25, 2014, 07:40:01 PM »
There is a problem with the display of the string for the Movie Scraper Layout "D" in Setup options.   :)
« Reply #2 on: December 25, 2014, 07:42:46 PM »
Thanks - already noticed this but did not want to hold this beta up for this. Will fix it.
Offline inikad
« Reply #3 on: December 25, 2014, 07:46:46 PM »
No problem. It was just in case you didn't notice it.  :)
Offline inikad
« Reply #4 on: December 25, 2014, 09:16:41 PM »
When you use manual scrape, titles and descriptions of movies that you can choose are in the correct language, but not the poster used by default: it's always the english poster. So you have to systematically  edit after a manual scrape to find the poster in your own language. With automatic scrape, no problem.
PS: just a question about manual scrape: is it normal that it always uses the "A" layout during edition, no matter if you choose another one in setup? No problem after you save it (about.jpg display the good one), but I asked myself why it doesn't use the layout selected in setup during edition.
« Last Edit: December 25, 2014, 09:27:44 PM by inikad »
Offline m3dmer3er3r_4
« Reply #5 on: December 25, 2014, 10:30:03 PM »
where i find new  skintemplates? can you download this ftp? New Scrape_layout mess custom skin if using custom scaper image. Could have been even mentioned this.
« Last Edit: December 25, 2014, 10:35:31 PM by m3dmer3er3r_4 »
« Reply #6 on: December 26, 2014, 11:20:58 AM »
Skinning became a problem when A B selection was introduced in 3.0.6. It was an onversite to not mention that in the past. We upgraded the 3.0.6 changlog last week, and added a reminded to 3.0.7 in blue.
It is hoped that the skinning issue will be resolved as part of debugging the new scrape layouts. When that is ready to be tested alternate scraper skins will be made public.
« Reply #7 on: December 26, 2014, 04:05:37 PM »
I probably understood it correctly .. (sorry for my bad english here)but the skin work fine V3.0.7 - 13Dec2014 BETA. Problem occurred with the latest. New scraper skin stretch custom scraper image fully about.jpg screen area.  :o
« Reply #8 on: December 26, 2014, 04:10:06 PM »
Pls let me know what skin you are using and we will check it
« Reply #9 on: December 26, 2014, 04:21:35 PM »
I use Mik3R button skin with own custom and own generic.png scraper image.. and was selected scraper A. Now, I returned back to the previous version of fw (dec13)
« Reply #10 on: December 26, 2014, 04:34:57 PM »
Please check the original unmodified skin.
« Reply #11 on: December 26, 2014, 04:47:47 PM »
what it should look? all images is correctly right size and the right shape..
« Reply #12 on: December 26, 2014, 04:58:08 PM »
Using GUI skins and screen size is known to have issues. Is that what you are doing?
« Last Edit: December 26, 2014, 05:50:59 PM by jer1956 »
« Reply #13 on: December 26, 2014, 06:00:17 PM »
@m3dmer3er3r_4
Sorry but the Scraper skin specs changed on this release.
Pls check attached file for updated specs for Scraper skin image  'generic.png' 'frame_old.png' 'generic_c.png' 'generic_d.png'
Scraper skin naming
a:
b:
c:
d:
Offline adamforeman
« Reply #14 on: December 26, 2014, 07:44:24 PM »
This is more of a feature request:
But I'd love to see more information about the movie properties eg: SD, HD, 1080p, 720p, dts, Dolby Digital, Dolby Prologic etc etc
Is that possible to add to the feature request list? The reason why I'm asking is that if you're playing around with the Scraper Layouts and skinning, it might be worth thinking about where to place the extra information on screen.
Many Thanks
