Author Topic: Scrapping TV shows with Yadis 2.3  (Read 5095 times)
Offline Bob2553
« on: December 23, 2014, 01:50:41 pm »
I have a Mede8er MED600X3D with version 3.06
I discovered recently that Yadis could help me creating additional data for my movies with better control
I have tried the same with my TV shows folder but this is not working
The "about" box is reffering to thetvdb.com as reference but the configuration dialog is just showing TMDb where TV shows are obvioulsy not documented
When adding a folder for scan, only "Movie" type is allowed
Is there a way to configure Yadis to get it working for TV Series?
Another point, Yadis is not creating a XML file in the target directrory
How can I get this done?
Thank you in advance for your help
Bob
« Last Edit: December 23, 2014, 02:08:09 pm by Bob2553 »
Offline TonP
Re: Scrapping TV shows with Yadis 2.3
« Reply #1 on: December 24, 2014, 01:55:31 pm »
Use yaDIS2mede8er for getting an XML file in your destination folder.
You can find this program in the "Yadis for Mede8er" subforum, first topic.
Ton
Offline Bob2553
« Reply #2 on: December 24, 2014, 03:24:43 pm »
Thank you Ton
I have tried that already
yaDIS2mede8er is scanning all movie folders but not generating the corresponding XML file where it is still missing
How can I tell yaDIS2mede8er to process all movies whatever there is a XML file or not?
(By target directories, I mean the structure on my NAS, not the Yadis structure onmy PC)
Cheers
Bob
« Last Edit: December 24, 2014, 04:13:08 pm by Bob2553 »
Offline TonP
« Reply #3 on: December 24, 2014, 04:42:36 pm »
Well, all I can think of is that you didn't check the selection box for xml files in the Yadis2mede8er setup screen.
Did you follow the tutorial from begin till end?
Ton
Offline Bob2553
« Reply #4 on: December 25, 2014, 01:23:49 pm »
I did check the selection box for XML files
However, I discovered all XML files in the movie root folder and not inside each movie folder
I have moved all of them manually
That's solved now. Thank you for your help Ton
Still have the problem to scan the TV shows folder
Merry Christmas
Bob
Offline Mr Eric
« Reply #5 on: January 13, 2015, 12:10:12 pm »
there's no mede8er support in yadis or yadis2mede8er for TV shows. You need to use something else for that.
Yadis beta team member
