Author Topic: X3D_ButtonSkin3_by_Cinoche (mod of original button skin of Mik3R)  (Read 7062 times)
A modded skin made by Cinoche.
Other fonts and background compared to the original skin by Mik3R as found here:
http://www.mede8erforum.com/index.php/topic,13569.0.html
Also FIRST update your Mede8er to V3.0.2 or higher otherwise this Skinpack will not function properly.
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download X3D_ButtonSkin3_by_Cinoche.rar
Offline Mik3R
Re: X3D_ButtonSkin3_by_Cinoche (mod of original button skin of Mik3R)
« Reply #1 on: August 31, 2016, 03:22:57 pm »
I like those buttons ;)
