Author Topic: Feedback for - V3.0.7 - 13Dec2014 BETA -X3D Series  (Read 30610 times)
« on: December 12, 2014, 07:47:03 PM »
Offline couto
Re: Feedback for - V3.0.7 - 13Dec2014 BETA -X3D Series
« Reply #1 on: December 12, 2014, 09:54:57 PM »
Translation to  portuguese
1. Thumbnail Colour .... thumbnail translated is (small images ) but its better to leave ( Cor Thumbnail ) Thumbnail is like universal word
1. Default (Original)
2. Blue (azul )
3. Green (verde)
4. Light Blue (azul claro)
5. Orange (laranja)
6. Red (vermelho)
7. Yellow (amarelo )
8. Browse (procurar )
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
nenito2k
  • Guest
« Reply #2 on: December 13, 2014, 10:42:02 PM »
Translation in FRENCH :) my native language  :P
1. Thumbnail Colour = couleur des vignettes
1. Default                  = Défaut
2. Blue                      = Bleu
3. Green                   = Vert
4. Light Blue             = Bleu clair
5. Orange                 = Orange
6. Red                       = Rouge
7. Yellow                   = Jaune
8. Browse                 = Parcourir
This is 100% accurate  ;D
Offline eBuTeb
  • Helpful Contribution Status: +2/-4
« Reply #3 on: December 13, 2014, 11:04:46 PM »
Translation in German
1. Thumbnail Colour = Farbe Selektionsrahmen (short: Selektionsfarbe)
1. Default                  = Standard
2. Blue                      = Blau
3. Green                   = Grün
4. Light Blue             = Hellblau
5. Orange                 = Orange
6. Red                       = Rot
7. Yellow                   = Gelb
8. Browse                 = durchsuche
MED500x2, V3.0.4
HDD INT = WDC WD15EARX (SATA 300/1,5 TB)
MED1000x3D, V4.0.2 (29. Jul Beta)
HDD INT = HGST H3IKNAS40003272SE (SATA 600 / 4 TB)
HDD USB 1-4 = Seagate ST2000DL003 (USB 3 (& HUB), NTFS)
NAS 1 = Thecus N4200eco
Router = AVM FritzBox 7390
TV = LG 55LM860V
Receiver = Onkyo TX-NR515
Offline cyberpapa
« Reply #4 on: December 14, 2014, 09:19:04 AM »
Translation in Nederlands (Dutch)
1. Thumbnail Colour = Miniatuur kleur
1. Default                  = Standaard
2. Blue                      = Blauw
3. Green                   = Groen
4. Light Blue             = lichtblauw
5. Orange                 = Oranje
6. Red                       = Rood
7. Yellow                   = Geel
8. Browse                 = Doorbladeren
« Last Edit: December 14, 2014, 09:31:26 AM by cyberpapa »
Offline Sunfish
« Reply #5 on: December 14, 2014, 11:11:42 AM »
Transmission switches off on its own with this firmware. It already happened a second time now within 12 hours.
« Reply #6 on: December 14, 2014, 11:12:57 AM »
Whilst the player is on, not after a reboot? Had all  downloads completed? Bt torrent  does have a Shutdown on Completion mode. ITs considered bad Torrent Etiquette to use it.
« Last Edit: December 14, 2014, 11:18:50 AM by jer1956 »
Offline Sunfish
« Reply #7 on: December 14, 2014, 11:18:08 AM »
Yes. The device is on day and night, always downloading torrents.
I just re-enabled Transmission and the player responded with "the device will spin up." I never set a HDD standby so it shouldn't spin down. I reconfirmed all settings.
« Reply #8 on: December 14, 2014, 11:20:10 AM »
The code cannot  prevent drives which  shut down of their own  accord from doing so. You would have to  connect the drive to a PC and use the drive makers own tool to  change that.
Did you leave the player on the Home Menu, and just use the BT Web interface. The shut down your getting could be the players Auto-standby.  It cant be fully integrated and overridden  by BT.
Offline Sunfish
« Reply #9 on: December 14, 2014, 11:22:22 AM »
It never did before this new beta though. Until the update it had been downloading nonstop for over a week.
« Reply #10 on: December 14, 2014, 11:25:19 AM »
Have you used all  the betas, including the first to  have BT v2.84?
V3.0.7_4Dec2014 BETA]
2. Dev - Transmission BT : updated to v2.84
Offline Sunfish
« Reply #11 on: December 14, 2014, 11:31:56 AM »
No, the previous firmware I used was V3.0.7 of 24 Oct 2014.
« Reply #12 on: December 14, 2014, 11:41:45 AM »
Repost as a Networking Issue with V2.84.
HerrTim
  • Guest
« Reply #13 on: December 14, 2014, 12:39:30 PM »
2. Blue                      = Blau
3. Green                   = Grün
5. Orange                 = Orange
6. Red                       = Rot
7. Yellow                   = Gelb
8. Browse                 = Durchsuchen
Offline manuelvis
« Reply #14 on: December 14, 2014, 02:07:43 PM »
Translation to  spanish
1. Thumbnail Colour = "Color en Miniatura" although you can use it too in english as universal words.
1. Default = Por Defecto
2. Blue = Azul
3. Green = Verde
4. Light Blue =  Azul Claro
5. Orange = Naranja
6. Red = Rojo
7. Yellow  = Amarillo
8. Browse = Explorar
