Author Topic: Feedback for - V3.0.7 - 11Dec2014 BETA -X3D Series  (Read 3029 times)
« on: December 11, 2014, 05:46:58 pm »
Please post your feedback here.
Offline vbb
Re: Feedback for - V3.0.7 - 11Dec2014 BETA -X3D Series
« Reply #1 on: December 11, 2014, 06:24:39 pm »
Subtitle search for TV shows with a year in the name has been fixed. This is why you guys are the best!
Sharp LC-70LE857U
Onkyo HT-RC360
Synology DS1813+ & DX513
HTPC running Kodi with MPC-HC + madVR
PLEX for everything else
Offline K.B.Nikto
« Reply #2 on: December 11, 2014, 06:54:25 pm »
So, all during that prolonged discussion about the issue, good old Mede8er1 was simply incorporating a fix. Rock on! Agreed that tech support is truly great!
« Reply #3 on: December 11, 2014, 07:03:51 pm »
Thumbnail colour change not updating the Favourites screen - will report this
« Reply #4 on: December 11, 2014, 07:42:29 pm »
Crashing during 'EDIT' scrape and saving on Samba share - will investigate
HAVE TEMPORARILY REMOVED THIS RELEASE AND WIL POST THE LINK ONCE THIS ISSUE IS RESOLVED
Offline pallec
    • Guitarfix
« Reply #5 on: December 12, 2014, 07:56:36 am »
I thought this was fixed now in this 11 Dec beta? Wasn't there a 10 Dec beta where this was the issue.
Or, maybe I am just getting confused because I have received two email about the same relaese..?
Connected to:
Netgear C6250 router
Synology DS214+ NAS (NFS)
Samsung UE65F8000 TV
Panasonic PT-AE2000 Projector
SONY STR-DN1040 AV Receiver
www.guitarfix.dk
« Reply #6 on: December 12, 2014, 09:15:46 am »
An issue was observed with scan/scrape after applying a skin. So it was pulled. Failed scans can  result in orphaned open  files....and that confuses  the NTFS emulator. Its not safe to  have the emulator not working as it should.
The year problem is that it was originally added for movies, and some have used it for TV. That had not been tested as it was not the original purpose. The search routines are completely different .
So all earlier references to fixing year was relative to its design purpose..movies. Only in this release where fixes to the unexpected use of it with TV made.
« Last Edit: December 12, 2014, 09:30:51 am by jer1956 »
« Reply #7 on: December 12, 2014, 07:31:34 pm »
Locked - new release
