Author Topic: Feedback for - V3.0.7 - 4Dec2014 BETA -X3D Series  (Read 35430 times)
Re: Feedback for - V3.0.7 - 4Dec2014 BETA -X3D Series
« Reply #30 on: December 06, 2014, 05:58:35 PM »
The sub search function still only shows the series name for me. Am I missing something?
Pls give us a few examples of the episode file names that you having this problem with.
Offline drfruit
« Reply #31 on: December 06, 2014, 07:35:45 PM »
I can only give one, as I rarely use the sub search function (most subs are automatically downloaded):
Forever.2014.S01E10.HD.TV.mkv
The search box only showed "Forever".
« Reply #32 on: December 06, 2014, 07:55:42 PM »
Do you get a looking glass top right?  It could be the TV has been jukeboxed and the search is based on the folder name...which is OK for movies.
Offline drfruit
« Reply #33 on: December 06, 2014, 08:04:46 PM »
I use the scan function for my tv series to get proper looking folders without the extra jpg's; no idea if that means it is jukeboxed.
Offline drfruit
« Reply #34 on: December 06, 2014, 10:47:19 PM »
Just checked, and yes, I get a looking glass when I search for subs.
Here is another show with the same problem:
Doctor.Who.2005.S08E09.1080p.WEB-DL-ECI.mkv
The subtitle search box just says "Doctor Who".
But with:
About.a.Boy.S02E06.1080p.WEB-DL.mkv
I get a season and episode number, although the file name is slightly changed:
About a.Boy S02E06
I guess the year in the names of some shows is causing the problem.
« Reply #35 on: December 07, 2014, 10:35:38 AM »
This is not according to normal naming conventions for series.
You will get also issues using other external scrapers or e.g. XBMC with this kind of names.
Just my 2 cents.....
« Reply #36 on: December 07, 2014, 10:41:06 AM »
Still some translation error in Dutch.
Verander catergory -> should be: Verander categorie
Offline drfruit
« Reply #37 on: December 07, 2014, 11:57:57 AM »
Not sure what you mean by "normal naming conventions". I guess you refer to the year in the file name?
This is how the shows are downloaded from usenet using standard software. On addic7ed.com, they specifically ask if "Forever (2014)" is what is being looked for.
I have no episodes left of Forever, but the other show I mentioned, Doctor Who, uses the same method of file naming.
XBMC works just fine with it, it shows the correct show and all the available episodes.
Re:
« Reply #38 on: December 07, 2014, 12:17:36 PM »
What I mean with standard naming convention is as defined in the mede8er TV series guide. If you move away from that you are at risk it does not work. Simular risk you have if you move away from naming conventions mentioned by other scrapers. And sure usenet downloads can have all of crapy naming.  But is that then the standard to follow?
Offline drfruit
« Reply #39 on: December 07, 2014, 12:46:04 PM »
We are not talking about crappy names, but about the standard way standard downloads are postprocessed by standard download software.
What exactly is wrong with the naming of these episodes? If it is the year, why not just say so?
Offline ozsolt
    • Company website
« Reply #40 on: December 07, 2014, 08:38:02 PM »
Read the User's guide first, please: link...
Mede8er distributor - Hungary
DENON AVR, Synology NAS, every Mede8er X3D model
Offline drfruit
« Reply #41 on: December 07, 2014, 10:20:40 PM »
Thanks, but if it is too much trouble to just say what is wrong with it according to this User's guide, even though I believe it to be a very standard file name, just leave it, I have no time or interest to go reading a guide.
The file names I use are standard; they work in every player I have tried (including the Mede8er) and in XBMC and they are produced by very common software using default settings.
As I stated before, most of my subs are already downloaded automatically. I just wanted to point out a problem that I encountered in this specific sub search function so maybe it can be corrected.
If someone knows what the problem could be, let them say so. Just pointing to a user's guide is not helpful.
Offline vbb
« Reply #42 on: December 07, 2014, 10:31:50 PM »
drfruit's naming convention for those particular shows is actually correct. There are two shows named Forever, and the one he has is listed as Forever (2014), which should be named Forever.2014.SxxExx.Whatever.ext. The same goes for Doctor Who (2005). This is not to say there isn't potentially something else wrong in the folder/file structure or elsewhere.
Sharp LC-70LE857U
Onkyo HT-RC360
Synology DS1813+ & DX513
HTPC running Kodi with MPC-HC + madVR
PLEX for everything else
Offline drfruit
« Reply #43 on: December 08, 2014, 10:47:57 AM »
Thanks for confirming.
The problem is not on my side, as in other shows that do not have a year in the file name, the improved sub search function works correctly.
It seems obvious that the search function is confused by the year in the file name, as it is the only difference between the cases where it works correctly and the ones where it only shows the part before the year (which is the show title).
Offline aragah
« Reply #44 on: December 09, 2014, 08:17:07 AM »
Just an idea: you might try with Forever.(2014).SxxExx... and Doctor.Who.(2005).SxxExx...
MED600X3D
Firmware: V4.0.0 - 2Jan2015
