Pages: 1 [2]   Go Down
Author Topic: Getting NFS to work with mede8er and Synology NAS?????  (Read 5802 times)
« Reply #15 on: May 24, 2012, 05:52:44 pm »
Hi Jakes,
The other threads are about a Synology NAS, you have another brand so it works a bit different.
I have no D-link NAS but looked at the manual.
Here my advise:
- first you need to enable NFS on your D-link on those NAS shares you want to access by NFS
Then you have some params you can set on your NAS NFS share:
Host - Allowable host address that can access using NFS
(* indicates all hosts). -> here you can limit what hosts ips can access the share. Put it on * first.
• Root Squash - Disables writing to the Root owned directories
and files on the system when the user has root access privileges.
-> set as desired, but for first setup and to be sure it does not block things, disable it.
• Write - provide write permission to the file system.
-> set this to write to be sure Mede8er Watched indicator will work and also Jukebox database can be written to the file NFS share
Now on your mede8er:
- goto Media Library
- goto Network
- goto NFS
- press Menu button on remote
- choose Add NFS
- for ip-adres fill in your D-Link NAS ip address
- for path fill in /Volume_1/video   (this is just a guess and depends what your volume name and shared folder exactly is
Wolfie
« Reply #16 on: January 13, 2013, 05:49:49 pm »
Mede8er500X & Synology DS412+
3 hours later it now works thanks "daanq" & "Maasbommel"
Mede8er path for me "Volume1/video"
Pages: 1 [2]   Go Up
