Author Topic: Need Help for template  (Read 5013 times)
Offline zenzidane
« on: November 05, 2014, 10:42:04 pm »
Hi guys,
I'm New To Mede8er, I neee couple of help.
1. i need Template for yadis, darkpolar, 3.10 to yuma and relax or other new template , that compatible to yadis 2.3, i couldn't find it everywhere. all the download are broken. (mediafire preferable)
these are the sample :
2. also does anyone have bluray rip, truehd (bluray to mkv 1:1) and dvd rip for yadis case, i found it on y2m to mede8er but not fit with yadis, i couldn't resize it also. (Solved)
(Done it my self)
3. can yadis to mede8er output about.jpg 1280 automatically without have to resize them manually using dune profile?
thanks for all your help.(Solved)
(Done it my self)
« Last Edit: November 07, 2014, 07:00:32 pm by zenzidane »
Offline Mr Eric
Re: Need Help for template
« Reply #1 on: November 06, 2014, 08:54:29 am »
hi,
I will try to check if I've got some backups for the templates you are looking for. But chances are scarce :(
for the other questions I don't use Y2M and don't have a mede8er, so i can't help much...
Yadis beta team member
Offline zenzidane
« Reply #2 on: November 06, 2014, 11:28:28 am »
great, thanks a lot mr. eric, i just buying mede8er and i already got a lot from mpc forum but i like template from above which is hard to find since the forum already stop since 2013. thanks a lot. i hope it still exist. is this mr eric the same from mpc club ?
Offline Mr Eric
« Reply #3 on: November 18, 2014, 09:59:58 am »
yes I'm the same Mr Eric ;)
This is what I could find :
Dark Polar : http://www.mediafire.com/download/bh8zscp177prz6q/DARKPOLAR_1.0.zip
3:10 to Yuma : http://www.mediafire.com/download/bx8dslh52mhjj8t/3.10_To_Yuma.zip
Relax 2 : http://www.mediafire.com/download/d478xokq72zwv7j/Relax-2-Template.rar
I think that Dark polar is OK with the latest yadis version, but the other 2 might be only for yadis 2.1 (or even older) and won't have the saga screens, so you might need to add some parts in the xml.
