Author Topic: Windows Server NFS - Success!!!  (Read 31255 times)
Offline glpush
Re: Windows Server NFS - Success!!!
« Reply #15 on: July 29, 2015, 07:53:55 PM »
You're right there are always multiple factors, but v3 is just faster than v2. I'm fairly sure I tested this with the jellyfish videos when I was on 2008 (and using v3). My homeplugs are the big issue, for example tcp is actually faster than udp using them, however v3 was still good enough to get around even  this bottleneck. I'd love to know what it is about the 2012 implementation of nfs that's causing it to mess up though, in case there is a setting somewhere that would get it working with the mede8er again.
Also not being able to fast forward or skip mkvs with nfsv2 is a major issue, it's basically unusable. So with 2012 it's samba or nothing, which is definitely slower than nfsv3.
Thinking about it though, I'm screwed either way. At best I could never top 55mbps, which isn't enough for 3d. Might have to start saving for some new gigabit homeplugs.
« Last Edit: July 29, 2015, 08:50:58 PM by glpush »
« Reply #16 on: July 30, 2015, 07:24:17 AM »
What spec rate are those powerline  units?  As a rule of thumb, if your only getting x% with your current powerline, then that's what you get with any.
Offline jamesamoy
« Reply #17 on: November 18, 2015, 10:01:21 PM »
The images in the original post arent loading for me, when I download them my PC says they're not valid PNG files, and the thumnails in the post have a bad link icon.
Does anyone know the steps to implement this without the images?
Offline Hubszo
« Reply #18 on: April 23, 2016, 02:52:52 PM »
I also can't see images from the first post although I'm logged in. Please fix this.
Player: Med600X3D FW 3.0.6 + WD My Book V2 4TB + wired (static IP)
TV: Panasonic Viera TX-P55VT50
A/V Receiver: TX-NR609
Language: English, Polish, Norwegian
Offline lubi
« Reply #19 on: January 11, 2017, 11:54:39 PM »
me too, I cannot view png files.
Offline anxion
« Reply #20 on: February 27, 2018, 09:18:48 PM »
hi could you share pictures again with us. Please?
Offline Sierra
« Last Edit: September 03, 2018, 11:49:59 AM by Sierra »
