Author Topic: MED250X CD File Playback  (Read 9089 times)
Offline decibel
« on: October 27, 2014, 01:23:59 PM »
I am having problems playing "CD" folders.  Once finally in the music files, if I select menu on the remote I then get the options:
1.  Repeat Off,
2.  Repeat all
3.  Shuffle Loop
The repeat off option works at individual song levels, but I would like to find a way to apply it to the CD folder.  In other words I would like to play one CD and then no further action unless I initiate it.
Is there any way I can check firmware level of the MED250X without just downloading and installing the latest?
Any help will be appreciated.
Re: MED250X CD File Playback
« Reply #1 on: October 27, 2014, 05:21:38 PM »
You can check the firmware version in setup, latest submenu.
There should be some info section where you can see the version.
Dont have a 250X myself, so this is a best guess.
Offline decibel
« Reply #2 on: October 29, 2014, 02:48:14 PM »
Thanks the firmware issue is resolved. Sorry I missed the newbie guide but I ignored any post not referring the 250X. :)
