Author Topic: Feedback for - V3.0.7 - 24Oct2014 BETA -X3D Series  (Read 22332 times)
« on: October 25, 2014, 07:24:09 am »
Pls post your feedback here
Offline omiz321
Re: Feedback for - V3.0.7 - 24Oct2014 BETA -X3D Series
« Reply #1 on: October 25, 2014, 10:13:26 am »
Nice beta with fast response to googles actions :D But when is 3.0.7 final coming out? Are you having something big coming up?  8)
Offline schap
« Reply #2 on: October 25, 2014, 12:12:43 pm »
At worldnews all icons are gone and Facebook still gives an SSL handshake problem.
hope you'll can fix this.
regards Schap
Offline henkie300
« Reply #3 on: October 25, 2014, 04:03:11 pm »
ik wacht ook op de final v3.0.7
en hoop dat popcorn time en netflix ook erbij zit
gr henk
Offline omiz321
« Reply #4 on: October 25, 2014, 09:24:12 pm »
Just small thing but on the update page it has small flaw:
STEP2
Install V3.0.7 - 4Octt2014Beta
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/2014/X3D_Series_V3.0.7_BETA_24Oct_2014.zip
It says install 4oct2014beta instead of 24 ;)
« Reply #5 on: October 26, 2014, 04:24:32 am »
It says install 4oct2014beta instead of 24 Wink
Fixed
Offline uka
« Reply #6 on: October 26, 2014, 02:47:01 pm »
V3.0.7_24Oct2014 BETA
1. Replaced YouTube HTML5 on Home Page with YouTube Flash
2. Fixed Hebrew Scrape on Movie Scraper - TMDB
3. Fixed Dutch translation that was omitted on last release
4. Portuguese GUI Language update
Always the same fix unimportant things,But legible subtitl nothing !!!!!
Offline wajs
  • Helpful Contribution Status: +3/-1
« Reply #7 on: October 27, 2014, 09:16:14 pm »
I agree with you.
Offline JuniorClass
« Reply #8 on: October 29, 2014, 05:48:50 am »
*legible subtitle
does this is mean make the subtitle easy to read .
you could change the font color , font size . line position .
if you are unhappy with the font , you could change the font to any font you like . thats work fine for me . if none of these then i don't know what you speaking about  :P
 Thanks for the quick youtube fix .
Offline m3dmer3er3r_4
« Reply #9 on: October 29, 2014, 04:57:25 pm »
That is true.. font replacement  help a little,but readability is still not good.Clear, bold, black border font is best viewed in all backgrounds..
« Reply #10 on: October 29, 2014, 06:03:00 pm »
Sanji can only fix what can be fixed. They have experimented with tricking the chip into doing multiple shadows and those with issues say its not good enough. The implication is either it works as those with issues want , or sanji shouldn't bother.
Only a few complain about the subtitles, yet everyone lost YouTube. To say fixing YouTube was unimportant  does undermine any feeling the complaints about subtitles are objective.
« Last Edit: October 29, 2014, 09:26:55 pm by jer1956 »
Offline turls
« Reply #11 on: October 30, 2014, 05:04:31 am »
Sorry for being late on this, just got my MED600X3D integrated correctly into my HT setup.
From the 3.0.7 17June Beta notes:
3. Dev: spdif audio: auto set audio config to support Core 5.1 passthrough when using HD Audio ie DTS MA/Dolby True HD on SPDIF
This seems to mean that the problem of passing through 5.1 audio on the SPDIF output while DTS MA/Dolby True HD on HDMI was fixed, but it is not.
The problem is D-BOX.  D-BOX expects 5.1 audio through SPDIF--it does not support HDMI.  It expects that stream to be exactly like the original, no adulteration.  Oppo Blu-ray players support this just fine.  This is how D-BOX detects which movie is playing and engages the proper motion effects.
I've upgraded to the newest firmware using the Emergency procedures, and any time I output full HD audio, it breaks D-BOX.  It works fine if I force it either through the main audio menu setting to 5.1 or force the audio settings while playing a Blu-ray to non-HD audio.
Can this actually be fixed?  Or am I misunderstanding what this note is about?
Maybe it is outputting SOMETHING (I don't have it hooked up to check, because that is irrelevant to me), but there is no question it is outputting differently depending on if it is HD Audio or not.
« Reply #12 on: October 30, 2014, 08:43:02 am »
Turls,
I don't read it that way. I read it to mean if HD audio over HDMI is not supported by the HDMI connection, then the new spdif Auto mode will perform core extraction, though the core is actually a separate track for truehd. So I think only dts-ma will benefit.
It dosnt mean simultaneouse HD audio over HDMI, and core over spdif.
Remember up to this change spdif users where stuck with either unprocessed SD audio passthrough, or stereo downmix. Any  file had to contain a suitable SD audio track for surround over spdif to work.
« Last Edit: October 30, 2014, 08:59:20 am by jer1956 »
Offline turls
« Reply #13 on: October 30, 2014, 01:04:24 pm »
Thanks for the feedback.  You very well may be right.  I hope if what I describe is possible then it is looked at.  As I said, Oppo does simultaneous HD Audio over HDMI while outputting 5.1 over SPDIF, so its possible, but maybe not with the Mede8er hardware.  I realize its a specialized request for a niche product, but its an important issue to that group.
« Reply #14 on: October 30, 2014, 03:21:21 pm »
Oppos are high end kit made from descrete chips. The x3d uses the integrated 1186 chip on a take it or leave it basis....and realtek only make budget chips with average users in mind.
