Author Topic: V3.0.5 - 12Oct2014 Beta for ME500X2, MED450X2/S, MED400X2/S  (Read 6766 times)
« on: October 11, 2014, 09:20:07 pm »
Hi All X2 Users
Download X2 Series - V3.0.5 - 12Oct2014
www.mede8er.org/beta/Firmwares_Beta/X2_Series/V3.0.5_12Oct2014_BETA.zip
Changelog  V3.0.5  - 12Oct2014
1. Improved default GUI navigation speed and updated default background image.
2. Fixed problem that local trailer plays by default from Movie JukeBox and users cannot play the actual movie - ignore 'movie.name.trailer.*' for users with X2 and X3D series who use local trailers.
Changelog  V3.0.4  - 22May 2014
1. Fixed Shoutcast Internet Radio
Changelog  V3.0.3  - 13May 2014
1. Fixed - Scraping Agreement Page remaining after accepting the terms when doing a EDIT first time after install
Changelog  V3.0.3 BETA  - 12May 2014
9. Dev. allow about.jpg EDIT directly after firmware update - old way you had to do a 'Scan' first in order to see the Agreement  Page.
Movie Scraper Skin 'A'
New TV Series Skin
Online Movie Scraper Guide
Online Jukebox+ Guide
JukeBox Plus
JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files. Do not set the favourite link to  an actual jukebox as the jukebox+. Using jukebox+ Reset may then delete your media!
If you  find your self in this position, remove/disconnect the host store for the jukebox+, and then perform a Reset Jukebox+. That might require you shutdown first and remove drives, lan  cables etc.   After doing the reset, shutdown again, are reconnect the removed storage.  Favourites will now show "all"  the links including a working jukebox+,  but the Menu  now has the Aggregate Jukebox option to  create the dummy you should have in the first place.  Until you  do  that, Add to Jukebox+ won't appear again. You can then  turn the wrongly used folder back to  a media store.
JukeBox Plus Instructions
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X2. Plug the power jack back in and then hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
« Last Edit: October 11, 2014, 09:37:05 pm by Mede8er1 »
