Author Topic: Aeon Q5 - EN  (Read 9932 times)
Offline outcorpse
Aeon Q5 - EN
« on: September 20, 2014, 03:13:12 PM »
Hi Guys,
Something that's long requested. Hope you enjoy this one i ported.
https://mega.co.nz/#!GsNiSCrY!sWBclm-YhoGB2w229riDxVNPcZzr2MGsnhEmyiA9odQ
Kind Regards,
Outcorpse
Offline fwulle
Re: Aeon Q5 - EN
« Reply #1 on: September 26, 2014, 01:28:59 PM »
Hi Outcorpse
Thanks for your work. I love your Skin.
Unfortunately the Bar on the Media-homepage is jumping a little bit. It seems the image size and quality isnít the same as on the other four homepages.
Could you change that? Thanks in advance.
fwulle
Offline outcorpse
Re: Aeon Q5 - EN
« Reply #2 on: September 26, 2014, 06:29:54 PM »
Hi Fwulle,
Thank you for your post. Glad you like the skin. I will check into this. What type of TV and HDMI cable are you using? I will try and re-compress that specific page with a different tool and re-upload.
Kind Regards,
Outcorpse
Hi Outcorpse
fwulle
Offline fwulle
Re: Aeon Q5 - EN
« Reply #3 on: October 24, 2014, 03:14:21 PM »
I use a FullHD Beamer and a normal HDMI cable.
Below I added a screenshot comparison link of the Favorites-Page and the Media-Page.
Hopefully my Problem is a little bit clearer now.
http://screenshotcomparison.com/comparison/97214
Offline outcorpse
Re: Aeon Q5 - EN
« Reply #4 on: October 31, 2014, 04:29:40 AM »
Sorry m8e,
This looks wrong yes. I will fix it as soon as i get a chance.
Kind Regards,
Outcorpse
