Author Topic: Feedback for V3.0.7 - 31Aug2014 BETA -X3D Series  (Read 31477 times)
Offline Mayday
Re: AW: Feedback for V3.0.7 - 31Aug2014 BETA -X3D Series
« Reply #15 on: September 06, 2014, 11:25:29 AM »
24h for the clock please.
Offline Mimen
  • Newbie and a bit confused
Re: Feedback for V3.0.7 - 31Aug2014 BETA -X3D Series
« Reply #16 on: September 07, 2014, 09:58:37 AM »
Oh no, I just upgraded to 3.07 and now my 1000 X3D cant find my modem. When I press the magnifying glass button it says "No AP found". I am logged on with the same modem to this site, so it can be the modem. Is there something else I should do?
Mede8er X3D
Firmware 3.0.4
Laptop Asus Sonic Master
Windows 8
Yamaha RX V373 Amp connected to HMDI cable to the Mede8er
TV LG 42LGF 20 Series connected - HDMI to receiver
Video settings (1080p 50Hz, ,16:9)
- Aspect Ratio (16:9);
- TV Out (I don’t know, cant find it)
- Digital Audio (Don’t know, cant find it)
Media source:
- Internal HDD – (ST300DM001)
Offline Flying_high
« Reply #17 on: September 07, 2014, 10:23:19 AM »
Is your PCI-E WiFi switched on?
You can lead a horse to water but you can't make it drink.
Offline forenuser
« Reply #18 on: September 07, 2014, 03:52:20 PM »
1. RESET if FullBD playback is started with activated BD menu after browser activity (e.g. watching internet trailers)
2. Language information not available after selection of certain track in movie playlist of a Full BD: If playback of a certain track is started from the playlist no language information is available for audio or subtitle selection. Due to this behaviour the right audio and/or subtitle track isn't selected automatically by the player.
See: http://www.mede8erforum.com/index.php/topic,14063.msg92205.html#msg92205
3. Wrong Media Library screen: 1. Movie jukebox is configured using 3 lines - 1/1 blue screen, 2. Start one movie of from this jukebox 3. Press Mede8er key on the remote to jump directly into the Media Library an you will see this with 1/1 blue screen -> The Mede8er remote key is not resetting jukebox full screen mode.
See: http://www.mede8erforum.com/index.php/topic,14063.msg92181.html#msg92181
4. Long muting of DTS-HD audio: DTS HD audio is muted after pause -> play or chapter jump for at least 2s. I think this time is to long. Maybe it could be dereased to 1s or made user adjustable in steps of 0.1s. I never had any problems before this muting time was increased.
5. Wrong framerate during Full BD playback with menu: I case a Full BD can be played with BD menu it can occur that the main movie or some bonus feature is played with the wrong framerate. The reason for this behaviour is that the Mede8er can't adapt the framerate for each title/track. Instead the Mede8er plays all titles/track with the same framerate. This framerate choosen by the device can be different to the framerate of the main movie so that it is also played with a wrong framerate. The result is a bad user explerience due to stuttering. Best would be to adapt the framerate at the beginning of each part which is played from Full BD. Please regard that trailer, bonus features, menu and main movie can have different framerates!
6. Gapless audio playback not possible for single file flac/ape with track information in cue file: Gapless audio playback is not possible if single file ape/flac is played with title/track information available in the cue file. A hickup sound is played at the end of each track/title and the beginning of the next track/title. So far gapless playback doesn't work.
Offline Mimen
Re:
« Reply #19 on: September 08, 2014, 04:29:31 AM »
OK thanks guys. When it started working after switching it off, on and leaving it for a few minutes.
Mede8er X3D
Firmware 3.0.4
Windows 8
Media source:
Offline Ronaldk
« Reply #20 on: September 08, 2014, 11:07:08 AM »
I dont see any overscan on about.jpg or test .ts file with the default screen size ie untouched after firmware update.
Check the results yourself from Epiphan HDMI Capture unit
www.mede8er.org/artwork/temp/2014/Forum/overscan_tests_Epiphan_HDMI_Capture.zip
Thank you Mede8er1. Your files helped me establish that overscan of 4% is active on my LG 3D TV. After reading other post on the TV manufacturer forums I could finally resolve this by changing the aspect ratio to "just scan" setting. (still perplexed why this is not mentioned in their manual), which apparently forces 1:1 pixel mapping. Screen calibration no longer needed and all the playback zoom works perfectly with 2D content with no overscan on regular images or GUI.  ;D
Amplifier: Pioneer SC-LX57
Offline Flying_high
« Reply #21 on: September 08, 2014, 02:00:21 PM »
I'd like to add to this that artist, album and track information is not shown in the player screen on the right hand side.
« Reply #22 on: September 08, 2014, 06:02:54 PM »
Thanks for updating us and I am sure your post will assist others with the same issue.
Offline shosh
« Reply #23 on: September 10, 2014, 01:26:07 PM »
Can you add the option for the NFS, Sorted by Date, Sorted by Name.... pls
please also the option of Sorted by Rating
thank you in Advance
Offline Woops
« Reply #24 on: September 13, 2014, 08:36:20 AM »
Is it just me having problems with downloading subtitles?
Searching for Swedish (same as meny language) and get confirmation sub downloaded, but no file was ever downloaded..
Did also verify that the sub was actually available on Opensub.
Worked just fine in previous version.
Offline frizera
« Reply #25 on: September 13, 2014, 02:58:03 PM »
I observed the same problem with subtitles download and the new version 3.0.7 !?!?!
"If it's stupid but works, then it is not stupid"
« Reply #26 on: September 13, 2014, 03:15:54 PM »
Good news is the Opensubtitles download is now fixed. We contacted them and they sorted the issue.
Great service from Opensubtitles as this was all done today at very short notice.  ;D
Offline frizera
« Reply #27 on: September 13, 2014, 04:26:42 PM »
Great job Thanks  ;) ;)
Offline Woops
« Reply #28 on: September 13, 2014, 07:11:39 PM »
Good job!  ;D ;D
Thx!
Offline hmd
« Reply #29 on: September 17, 2014, 10:26:13 AM »
Hi, thanks for the great job
1- can you support the HEVC codec I video which I can not play.
2- we need more support for Arabic subtitle the best media player which support Arabic subtitle is XBMC
thanks a lot for your support
