Author Topic: Mede8er Movie Template for Thumbgen  (Read 5283 times)
Offline Slezz
« on: August 30, 2014, 03:31:35 pm »
Hi  :)
I just bought a MED600X3D and really like it so far. I had a WD TV Live Hub before and made my Moviesheets with Thumbgen. I used the Templates of the "GoodBye Black Mamba" Theme from DeVicious and modified it a little.  So I decided to make a Template for the Mede8er out of this Theme.
With Thumbgen Designer it is easy to modify, so you can change it to your needs (Language, Rating,..)
Just unzip the file in your Thumbgen folder. It also contains a profile.
Let me know what you think  ;)
DOWNLOAD
« Last Edit: August 31, 2014, 08:23:17 am by Slezz »
Re: Mede8er Movie Template for Thumbgen
« Reply #1 on: August 30, 2014, 04:43:34 pm »
Very nice  ;D
Offline Fmedrano1977
Re:
« Reply #2 on: August 30, 2014, 06:48:35 pm »
That is super clean! I use yadis, is thumbgen hard to use.
Sent from my HTC One_M8
Offline Slezz
Re:
« Reply #3 on: August 31, 2014, 08:48:56 am »
With the profile it is very easy to use. Everything is preset and you are good to go. You can do your movies manually or automatically. A moviesheet metadata file is generated for every movie, so you can easily redo your movies with other templates.
Offline eentje
« Reply #4 on: August 31, 2014, 03:18:22 pm »
thumbgen is very very easy to use :)
www.thetvdb.com contributor
