Author Topic: Firmware Installation Procedure  (Read 4520 times)
Offline wolf1255
« on: August 30, 2014, 11:52:13 AM »
hi,
I have done for a long time no update on my Mede8er 800X3D  more times today and wanted to make up for just. Had I known how time-consuming and cumbersome that's left I would not touch it.
I used to consider a DUNE HD Player with which it was simply a button in the menu to new updates and if you wolllte could download it right for him from the Web and install the same player. I call this simple and user-friendly operation.
Perhaps you could as a function so times in your considerations into account because I believe I am not the only one to unnecessary procedures such as are needed in the Mede8er totally annoying.
greets wolfgang
MacMini late 2012,Lacie Rugged Thunderbolt SSD,,Fritzbox 7330,2x3 TB HDD 1x1TB HDD,Synology DS 214play,MED800X3D
Re:
« Reply #1 on: August 30, 2014, 02:04:16 PM »
What was the trouble you had Wolfgang?
Update is pretty straight forward.
Offline wolf1255
Re:
« Reply #2 on: August 31, 2014, 07:01:56 AM »
i have tried to make the update like written in the newbie guide with a stick an the image on it, and press the key on the FB
10 to 15 sec. but there is happend nothing.
maybe im stupid but very easy it is to make updates self finding with an update function like above written from me.
greets wolfgang
Offline Larry56
Re: Firmware Installation Procedure
« Reply #3 on: September 18, 2014, 05:14:05 AM »
wolf1255,
I had the same issue and thought nothing was happening because, for some reason, it doesn't handshake with my AVR/television until the whole process has completed. The only thing that shows up on the TV is a message something like "incompatible video signal." It looks like nothing is happening but you just have to be patient and, when it's done, the screen will light up again with the X3D boot-up screen.
I do agree with you that it's annoying to go through the entire emergency procedure, first saving your config file, then restoring it afterwards. I also agree that the process could and should be made much easier, even over the internet if possible like most blu-ray players today. Strangely, on the X3D setting screen, there IS an option listed for "USB Update" but they never suggest we use that for some reason.
So next time you're doing an update, follow the emergency procedure like you've been doing (put the stick in, turn the player on while holding the power button down for 10-15 seconds and, whatever you do, don't interrupt it), this time be patient. After a few minutes (seems like about 5 minutes), it WILL install correctly but, yeah, you won't know what's happening until the screen comes back on. I have an older TV downstairs and another Mede8er X3D connected to that TV (through an AVR, same as the other), and that TV shows the update process with the progress bar and everything. But my newer TV shows the "incompatible video" message during the entire process for some reason. But I assure you it IS updating, even if you can't see what's happening for about 5 minutes.
Good luck,
~ Larry
