Author Topic: 3d ISO not switching automatically to 3d mode in my pj  (Read 5403 times)
Re: 3d ISO not switching automatically to 3d mode in my pj
« Reply #15 on: August 24, 2014, 03:24:34 PM »
And how with the laptop and power DVD as a source and with the same configuration (splitter) I had automatically frame packing?
Because they don't use edid. Only Realtek have implemented a fully edid dependent device.  With others sources you force the output you want....with no need for an edid saying its supported.
You would need something like this
http://www.gefen.com/kvm/ext-hdmi-edidp.jsp?prod_id=8005
..to make it appear that the spliiter was a "display", with an edid available.
Offline vagos1103gr
« Reply #16 on: August 24, 2014, 03:27:31 PM »
I see, then if am gonna live with that, thanks for your help.
