Author Topic: Issue with playing movies / yadis  (Read 16323 times)
Re: Issue with playing movies / yadis
« Reply #30 on: October 24, 2014, 06:00:34 pm »
The fact your frustration has ended is satisfying enough.  ;)
I did point out some posts earlier that this was your problem. The most used guides don't refer to this issue......my rather dry guide did. There is no single way to find your PC's ipv4 address, it depends upon your operating system.  So I didn't go into details.
« Last Edit: October 24, 2014, 06:06:37 pm by jer1956 »
