Author Topic: V3.0.7 - 20Aug2014 BETA -X3D Series - for MED1000X3D - MED800X3D - MED600X3  (Read 54243 times)
Offline Duppie
Thanks for this  ;) Waited a long time for it. Will test it once I have some time.
8. Fix: watched indicator: doesn't work on TV Series if you press NEXT >>| or PREV <<| to switch another episode.
Duppie
Offline sajidassad
Thanks for this updates dev team,, its great to see frequest development for this player and for new customer like me its amazing :)
Offline blink74
I did the last update and in practice I do not find more 'no cover for more of the various movies, TV series instead of all ok.
Sorry for my English but I use google translate, I'm Italian.
Offline djeqa3
  • Helpful Contribution Status: +1/-11
Can you fixed arabic subtitle please :(
Can you fixed arabic subtitle please Sad
Our engineers are busy investigating the Arabic sub issue and will report back once I know more.
Offline bazzio
Again the Mede8er hangs after adding the youtube code to the first xml in my aggr. jukebox. Like said before, if i delete the filelink code (links to the actual movies on my server) in the xml's then the youtube links are added without a problem.... Could you please look into this....
btw: It doesn't matter if i use jukebox+ or normal add to favorites,
Offline hdmkv
Tried the new firmware w/trailer function for the first time yesterday. Very nice. Thanks M8R.
You guys have made the X3 series great, so I'm wondering what's in your future plans? Realtek isn't releasing any new media player chips AFAIK. Android-based chips are still lacking... a couple (like VidOn.me) purport to support full 3D BD's, but not sure I believe the claims. I also converted all my 3D BD-ISO's to MVC MKV's especially for my X3D's, so I'm concerned about their playback in the future.
Firmware: Always Latest Beta
Networked via CAT5e
In a previous feedback topic you mentioned:
Yeh i think setup of jukebox + is ok.
But i think i found the problem. Because my movies are in different folders then the movie info (jpg's & xml) a have the filelink code in the xml to direct the jukebox to the right movie location. If i remove the piece of filelink code manually from the xml's then the mede8er adds all the youtube link succesfully one after another. And i don't need the video file to be in the same directory as the xml like i mentioned earlier. So there must be something going wrong with the filelink piece of the xml.
It looks like you use a very specific setup with that filelinks in your xml, as nobody else is posting simular issues....
Offline bazzio
Specific, i don't know... I use Yadis with links like this; Folder: \\Gebruik-q6tvorj\m\Films Dune Pad: nfs://192.168.0.52/m:/Films. After i'm done with Yadis, i use yaDIS2mede8er with the aggregate jukebox option on. This will make a aggr. jukebox on my server with only the yadis files (jpg's and xml) The actual movies are on other HDD's on my server (see yadis link above). That is why there are filelinks in the xml's.
edit: To be more specific, on my server i have (in this example) my M drive wich is called Films, on that drive i have a directory called Films with the actual movies. Aggregated jukebox is on the D drive called D Schijf.
« Last Edit: August 20, 2014, 11:49:57 AM by bazzio »
So you are using the yadis2mede8er aggregate jukebox method, and not the Mede8er aggregated jukebox (jukebox +) feature.
And the Add Trailer code is not to be compatible with that kind of old pre-Jukebox+ setup.
Have you tried if the local trailer method is working?
So I mean drop a trailer file in your movie folder?
Offline bazzio
Yes that is correct. I like to have my movies folders clean, that's why i still use this method.
No, but will try that. Can i use a mp4 file and name that trailer.mp4?
Use the same name as your movie with .trailer
So eg. Avatar.mkv gives for the trailer Avatar.trailer.mp4
Offline bazzio
Ok thanks, just tested it. Adding the trailer file works but only if i add it to the aggr. jukebox directory and not in the movie directory.
Yes..that is correct for aggragated jukeboxes. Its considered part of the scrape. So  are you saying you have a also have data folder in the aggragated parent?
