Author Topic: 3d ISO shuttering  (Read 3101 times)
Offline vagos1103gr
3d ISO shuttering
« on: August 18, 2014, 08:15:18 PM »
Hi, I just install my med8er 600xd but when I play 3d ISO through Nfs I have shuttering. With 2d rips I have smooth video. I gave AirPort Extreme router and tp-link tl-sf1005d Ethernet switch. The media box is connected through the switch to the router. Any help? I actually I bought the media for the 3d blu ray iso.
Offline eentje
Re: 3d ISO shuttering
« Reply #1 on: August 18, 2014, 08:19:18 PM »
might be the file :)
i have a 500x2 it streams most 3d isos no issues and it has a slower proc in it :)
www.thetvdb.com contributor
« Reply #2 on: August 18, 2014, 08:35:40 PM »
Did you set the NFS setting in the setup menu and then reboot the X3D? Normally UDP and 32K is best for 3DBDISO streaming.
Offline vagos1103gr
« Reply #3 on: August 18, 2014, 09:38:06 PM »
The same file was playing from the laptop with nvidia 750 sli and was playing smooth. No I didn't set up the NSF. I am gonna check it when I will be home tonight. Thanks for the fast response. Something else. How I play blu ray videos with more than one file?
Offline K.B.Nikto
« Reply #4 on: August 18, 2014, 10:08:45 PM »
It appears in quick searching that the tp-link tl-sf1005d switch is only 10/100. With the big file size of 3D ISOs, a 10/100 switch would certainly be a bottleneck.
If that spec is accurate, try a Gigabit switch.
Offline vagos1103gr
« Reply #5 on: August 18, 2014, 10:49:38 PM »
Thanks I ordered already in 2 days comes for testing. I will also try to connect straight to the router to see if it's the fault of the switch.
Offline vagos1103gr
« Reply #6 on: August 19, 2014, 04:44:58 AM »
So I went home and I connected the Ethernet straight to the router and I also change the Ethernet cable to a better one. The shuttering now is less but exist in blu ray 3d ISO. I am newbie with network  things. I usually play my ISO from the network and workgroup meany on media manager. I heard from NSF is faster. But I don't know how to create. My nas for example the ip is 10.0.1.10 and after I have to put folder path but I don't know what to put? Some body can help me with this?
Offline zed85
« Reply #7 on: August 19, 2014, 06:51:12 AM »
Could you extract a report of the file through MediaInfo? (http://sourceforge.net/projects/mediainfo/ )
I that way we could help you find the exact problem why the blu ray 3d iso is stuttering. Could be a bad created ISO.
Offline vagos1103gr
« Reply #8 on: August 19, 2014, 11:41:20 AM »
the same file playing from the laptop is not shuttering. am i doing right playing the iso file from the file manager and network/workgroup and not from nfs? and is not only this iso. there are another 3d that shuttering.how do i use media manager? i have to mount the iso with demon tools first? because i open like this and doesnt shows me anything in the media manager. thanks for your help
