Author Topic: Feedback for V3.0.7 - 7Aug2014 BETA -X3D Series  (Read 34254 times)
Offline sajidassad
Re: Feedback for V3.0.7 - 7Aug2014 BETA -X3D Series
« Reply #15 on: August 08, 2014, 01:27:35 pm »
my bad,,,weather widget working after selecting on setting
so far so good with latest frware
Offline ozsolt
    • Company website
« Reply #16 on: August 08, 2014, 03:12:24 pm »
After scraping a new folder with about 100 movie folders, the first two movies have the same trailer. I mean, the trailer of the second movie in my collection starts, when I select the trailer on the about.jpg of the first movie.
Please, remove the "." (dot) in the hungarian GUI at the end of "Előzetesek hozzáadása." (Add trailer) text. It was a misstyping only.
Mede8er distributor - Hungary
DENON AVR, Synology NAS, every Mede8er X3D model
Offline bacardicola
« Reply #17 on: August 08, 2014, 06:20:48 pm »
Thx guys, great job .
The bright white flash is gone and it returns to the right movie.
In Holland we say: "Petje af"  :)
Offline sajidassad
« Reply #18 on: August 08, 2014, 06:51:40 pm »
I am experiencing that video settings goes back to 1080p 50hz even if set to HDMI auto.. Is it known issue
jsmiddleton4
  • Guest
« Reply #19 on: August 08, 2014, 07:15:12 pm »
"It looks like some tmdb site issue, where tmbd updated their site code and now not compatible with specific browser versions. We currently cannot do anything about this on Mede8er code side and hope tmdb will optimize their website code."
I just hate it when some body "out there" changes their code so some feature on our media player doesn't work.
Re: Re: Re: Feedback for V3.0.7 - 7Aug2014 BETA -X3D Series
« Reply #20 on: August 08, 2014, 07:57:17 pm »
This is the result of the Auto FPS setting. Turn it off in setup if you want to keep hdmi on auto.  Auto FPS will auto switch to the movie FPS rate. This is normal behaviour.
« Reply #21 on: August 09, 2014, 06:24:03 am »
What movie was that exactly, movie name?
Have you checked that it has the correct trailer link in www.themoviedb.org/ and the base is not a wrong trailer link there?
Can you retry by removing the xml file in that folder and scan again?
« Reply #22 on: August 09, 2014, 07:09:33 am »
Can you copy the xml for both movies over samba, then zip and attach?
Offline m3dmer3er3r_4
« Reply #23 on: August 09, 2014, 11:32:44 am »
this thing probably already somewhere but..
why the delete and multiple select function is missing in movie jukebox+ ?
Offline blonk
« Reply #24 on: August 10, 2014, 04:06:45 am »
Tried to update to this firmware via the emergency procedure as described, but it wouldn't work. Can I use the upgrade via USB option from the menu? When I try, it find the file on the USB stick, and asks if I want to upgrade.
Blonk
Offline sajidassad
« Reply #25 on: August 10, 2014, 06:30:46 am »
what is te exact steps u doing for emergency procedure ?
it woks all the time if done properly
« Reply #26 on: August 10, 2014, 06:56:11 am »
Be sure that you format the usb stick fat32 before you use it to upgrade with emergency method.
Offline blonk
« Reply #27 on: August 10, 2014, 07:30:07 am »
USB stick is formatted FAT32. Install.img file is on its own in the root directory. I install the stick, unplug the power, plug it back in again, then press and hold the power button on the front of the unit for 15 seconds. The screen displays a mede8er image (a large one made up of two different shades of blue blocks), but nothing else. Left it for a few minutes but no response. Tried two different sticks and no difference. I used one for upgrading to 3.0.6 without a problem when I first got it. Is there an issue with upgrading via the USB upgrade option?
Blonk
Offline sajidassad
« Reply #28 on: August 10, 2014, 07:52:53 am »
is there a way to update youtube trailer link in xml ? I tried but seems the format is wrong ... any tool or something to edit that pls
« Reply #29 on: August 10, 2014, 08:01:41 am »
Put the focus on your favorite with the movies below. Then press menu button and select the Add Trailer option. It will update the links in the xml files.
