All my movies are in mp4 and AAC audio-codec. Never a problem until recently
Since this week I have a few movies which can not be played. (wrong file format- onjuiste bestandsindeling)
Is it a bug, or wrong codec?
Please help:
EDIT: I've uploaded an example through ftp
Created on: 21 Jul 2014 16:45:46 GMT+2
Report for file: The.Other.Woman.2014.mp4
General / Container Stream #1
Total Video Streams for this File.................1
Total Audio Streams for this File.................1
Video Codecs Used.................................AVC
Audio Codecs Used.................................AAC LC
File Format.......................................MPEG-4
Play Time.........................................1h 49mn
Total File Size...................................809 MiB
Total Stream BitRate..............................1 037 Kbps
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................avc1
Codec Profile.....................................High@L4.1
Frame Width.......................................1 280 pixels
Frame Height......................................536 pixels
Frame Rate........................................23.976 fps
Total Frames......................................156980
Display Aspect Ratio..............................2.35:1
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................CABAC / 4 Ref Frames
QF (like Gordian Knot)............................0.057
Codec Settings (CABAC)............................Yes
Codec Settings (Reference Frames).................4
Video Stream Length...............................1h 49mn 7s 374ms
Video Stream BitRate..............................939 Kbps
Video Stream BitRate Mode.........................VBR
Bit Depth.........................................8 bits
Video Stream Size.................................733 MiB (91%)
Video Encoder.....................................x264 - core 142 r2409 d6b4e63
Video Encoder (Settings)..........................cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=60 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=939 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Date of Original Encoding.........................UTC 2014-07-16 20:39:01
Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
Codec.............................................AAC
Codec (FourCC)....................................40
Audio Stream Length...............................1h 49mn 7s 434ms
Audio Stream BitRate..............................93.8 Kbps
Audio Stream BitRate Mode.........................VBR
Number of Audio Channels..........................2
Audio Channel's Positions.........................Front: L R
Sampling Rate.....................................48.0 KHz
Audio Stream Size.................................73.2 MiB (9%)
Audio Stream Language.............................English
Date of Original Encoding.........................UTC 2014-07-16 20:39:06
