Author Topic: X3 Night of the Stars Skin by Mede8er  (Read 47593 times)
« on: July 06, 2014, 09:57:35 AM »
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download X3 Night of the Stars EU - ENG V3 by Mede8er
Download X3 Night of the Stars USA - ENG V3 by Mede8er
Download X3 Night of the Stars Dutch V1 by Mede8er
Download X3 Night of the Stars French V2 by Mede8er
Download X3 Night of the Stars German V1 by Mede8er
Download X3 Night of the Stars Italian by Mede8er
You can customize the skin by replacing the Home Page Background  image 'BG_LAYER1.jpg' with any jpg image 1280x 720 pixels or by using the 'Set to Background' option - Remember to reboot the X3D for the new background image to show.
Examples
« Last Edit: January 14, 2016, 09:11:25 AM by Mede8er1 »
Offline aMadEUs
Re: X3 Night of the Stars Skin by Mede8er
« Reply #1 on: July 07, 2014, 04:39:56 PM »
Just perfect ! Thanks  ;)
Offline inikad
« Reply #2 on: July 07, 2014, 06:14:59 PM »
In the french pack, "HOME_PAGE_SETUP" seems to use a different color and a different font than the rest of the skin.
A really nice Skin.  :)
« Reply #3 on: July 07, 2014, 07:03:43 PM »
Night_of_the_Stars_Skin_French_X3D_Series_V1.zip
Updated
Offline TifKag
  • X2 Skin Designer
« Reply #4 on: July 19, 2014, 02:17:03 PM »
Is it possibl4e to make the skins you make and post, also available for the X2 in english and dutch (Like iDrive and Night of the Stars and Open Fields)
Thanks in advance for your answer
Offline soyangelv
« Reply #5 on: September 30, 2014, 10:51:14 AM »
Download X3 Night of the Stars EU - ENG V2 by Mede8er
Download X3 Night of the Stars USA - ENG V2 by Mede8er
Download X3 Night of the Stars French V1 by Mede8er
Examples
« Reply #6 on: September 30, 2014, 12:43:44 PM »
Night of the Stars will not run well on X2  as the whole screen needs to refresh and X2 does no have the resources to do this quick enough.
Offline inikad
« Reply #7 on: January 03, 2015, 11:27:14 PM »
You confirm that there is no problem to use the skin with new firmware 4.0?
I love this skin and use it by default since its release.  ;D
Offline fabris66
« Reply #8 on: November 10, 2015, 09:18:46 PM »
In italian language? I hope soon ... ;)
« Reply #9 on: November 11, 2015, 05:29:25 AM »
X3 Night of the Stars Skin by Mede8er Italian added
http://www.mede8erforum.com/index.php/topic,14660.0.html
Offline fabris66
« Reply #10 on: November 15, 2015, 09:16:04 PM »
Thank you! ;)
Offline Orton
« Reply #11 on: November 30, 2015, 08:57:41 AM »
Thanks will try to put it on.... new user
Offline aMadEUs
« Reply #12 on: December 09, 2015, 03:22:11 PM »
Hello!
Is it possible to get "IMAGE_SHUTDOWN.png" in french?
English > French
Power off. Please wait... > Arrêt en cours. Veuillez patienter...
Offline mike_carton
« Reply #13 on: January 08, 2016, 11:47:41 PM »
Nice work. I'm putting this on. However,
1) I noticed the following typo on "HOME_PAGE_MEDIA_LIBRARY.png". It says "Navigate all you local and network media via Samba, NFS and UPnP". It should say "Navigate all your local and network media via Samba, NFS and UPnP"
2) When I use this skin, the number of "Genre" icons shown in the listing while changing the genre becomes limited, it stops somewhere in the middle instead of showing all the icons.
X3D1000 running final 4.02
« Last Edit: January 09, 2016, 12:04:15 AM by mike_carton »
« Reply #14 on: January 09, 2016, 08:58:37 AM »
Updated:  Night_of_the_Stars_Skin_USA_ENG_X3D_Series_V3.zip
http://www.mede8erforum.com/index.php/topic,14660.msg95882.html#msg95882
Cannot find any problem with the Genre listings in 'Edit' with this skin
