Author Topic: X2 Relax Skin by Mede8er  (Read 16816 times)
« on: July 04, 2014, 10:15:11 AM »
NOTE: This skin is only compatible with Firmware V3.0.2 and up.
Download X2 Relax  EU - ENG by Mede8er
Download X2 Relax Dutch V1 by Mede8er
You can customize the skin by replacing the Home Page Background  image 'BG_LAYER1.jpg' with any jpg image 1280x 720 pixels or by using the 'Set to Background' option
« Last Edit: July 08, 2014, 04:36:51 PM by Mede8er1 »
Offline Mafalda
Re: X2 Relax Skin by Mede8er
« Reply #1 on: July 04, 2014, 01:29:43 PM »
Many thanks for this X2 skin and for all recently updated ones.
Mafalda
Offline TifKag
  • X2 Skin Designer
« Reply #2 on: July 04, 2014, 03:14:10 PM »
Offline Gogsysul
« Reply #3 on: October 26, 2014, 06:52:47 PM »
 ;D thanks
Offline Gogsysul
« Reply #4 on: October 30, 2014, 05:50:10 PM »
First of all, I'd like to thank Mafalda  for the skin...again  ;)
Secondly, would you mind if i used this as a template and try to make my own (similar) skin please?
Gogsysul
Offline Mafalda
« Reply #5 on: November 04, 2014, 11:30:23 AM »
Hi Gogsysul!
"X2 Relax Skin by Mede8er" was created by Mede8er, not by me. So I have no merit in this skin.
You could ask the moderators to be joined to the "X2 Skins Developer Group" where you will find instructions and tools to create your own skins.
http://www.mede8erforum.com/index.php/topic,8364.0.html
I wish you a successful work.
Mafalda
