Author Topic: iDrive Skin by Mede8er  (Read 26596 times)
« on: June 27, 2014, 03:09:04 PM »
Fun skin for all BMW fans
Also FIRST update your Mede8er to V3.0.7 - 27June2014 BETA or higher otherwise this Skinpack will not function properly.
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download iDrive by Mede8er
UPDATE - LATEST
Download iDrive V2 by Mede8er
NOTE - This Skin will only work correctly with V3.0.7 - 27June2014 BETA or later
http://www.mede8erforum.com/index.php/topic,14598.0.html
You can customize the skin by replacing the Home Page Background  image 'BG_LAYER1.jpg' with any jpg image 1280x 720 pixels or by using the 'Set to Background' option
« Last Edit: August 08, 2015, 05:13:06 AM by Mede8er1 »
jsmiddleton4
  • Guest
Re: iDrive Skin by Mede8er
« Reply #1 on: June 29, 2014, 03:24:28 PM »
Nice.
Offline TifKag
  • X2 Skin Designer
« Reply #2 on: August 08, 2015, 09:12:36 AM »
Great......Thank you  :)
