Author Topic: X3 Bubbles Skin by Mede8er  (Read 101092 times)
Re: X3 Bubbles Skin by Mede8er
« Reply #45 on: February 08, 2015, 01:45:14 PM »
Danish Bubbles added ;D
Offline ozsolt
    • Company website
« Reply #46 on: February 10, 2015, 10:57:44 AM »
The background with the bubbles is strongly compressed, it looks like a low resolution picture, not so nice. There is still graphics problem around the first episode preview, when we move the selection away in the TV series jukebox.
Mede8er distributor - Hungary
DENON AVR, Synology NAS, every Mede8er X3D model
Offline adamforeman
Re: Re: X3 Bubbles Skin by Mede8er
« Reply #47 on: February 10, 2015, 01:01:36 PM »
Are you sure that you haven't changed the hdmi output settings to 480p as that will cause the image to look heavily compressed
Offline Nodscene
« Reply #48 on: March 01, 2015, 05:51:12 PM »
There looks to be 3 different versions of this skin but I don't see anywhere that explains the difference between them. Could you possibly explain what the different types are please?
Offline intentus
« Reply #49 on: March 03, 2015, 06:04:19 PM »
It seems that only the buttons are translated. If translation of Danish descriptions are still needed, I could provide those. I am about to localize my own skin (still in test phase), so this would not be a problem for me (I use the same English descriptions on my skin). :)
Currently happy owner of the following gear...
    MED800X3D + 3 TB WD RED WD30EFRX
    USB 3.0 A-B cable (3 meter)
    ICIDU Express Card USB 3.0 Adapter (AI-707936)
    Pioneer BDR-XD05 (USB 3.0 Blu-ray Writer)
    Panasonic TX-P50VT60Y (TV)
    Yamaha RX-V775 (AVR)
    Dell Precision M4500 (Laptop: 8 GB RAM, Crucial 256 GB mSATA SSD + Samsung 120 GB SSD)
    Dune HD B1
    Popcorn Hour A-400 (died on me!)
Offline intentus
« Reply #50 on: March 03, 2015, 06:12:39 PM »
BG_LAYER1.jpg is only 84 KB, so compression will surely be obvious for some people. It does however not bother everyone. I am not a fan of visible compression artifacts myself, though (and I don't use this BG for the same reason, but I like the button layers).
I am not sure how well the player handles higher file size in BG layers, but a 150 KB file should be OK without "slowing down the player" and would most likely eliminate most visible compression artifacts in this BG?
    Dune HD B1
Offline brunathaur
« Reply #51 on: March 24, 2015, 02:22:37 PM »
Sorry for my english, i'm a french guy. How do you do to make movie icons 3x8 : the setup can only show 2x4 or 2x6 or 2x8 but not 3x8 ?
And can i put a background image for internet and another to media and another to youtube, etc...?
Offline brunathaur
« Reply #52 on: April 18, 2015, 09:55:51 PM »
OK. I've found...
Offline DR3AMMA5TER
« Reply #53 on: May 02, 2015, 05:49:32 PM »
I'm new to Mede8er and i have the same question as you did.
Can you share your answer with me because i really need to know how to get the covers like 3X8 view.
Offline m3dmer3er3r_4
« Reply #54 on: May 02, 2015, 07:19:55 PM »
Simple show/hide movie info under menu button in (jukebox+) view.
3rows works only with moviejukebox .
« Last Edit: May 02, 2015, 07:28:03 PM by m3dmer3er3r_4 »
Offline DR3AMMA5TER
« Reply #55 on: May 04, 2015, 12:08:40 PM »
Thnx for your answer, i'm gonna try that  :)
Offline margento
« Reply #56 on: June 26, 2015, 10:27:11 PM »
Italian bubbles, please!
FAVOURITES
PREFERITI
MEDIA LIBRARY
LIBRERIA MULTIMEDIALE
YOUTUBE
YOUTUBE
INTERNET
INTERNET
SETUP
IMPOSTAZIONI
Favourite shortcuts to JukeBoxes, Movies, Music and TV Series...
Collegamenti rapidi a Jukeboxe, Film, Musica e Serie TV...
Navigate all you Local and Network Media via Samba, NFS and UPnP...
Sfoglia i contenuti multimediali locali e di rete per mezzo di Samba, NFS e UPNP...
Search and Stream YouTube Videos and setup YouTube pair functionality...
Cerca e Riproduci Video di YouTube e imposta l'opzione "Accoppia dispositivo"...
Browse the Internet, Check the Weather, Play Internet Radio, IPTV & RSS Streams...
Naviga su Internet, Controlla il Meteo, Riproduci Internet Radio, IPTV e Flussi RSS...
Configuration Setup options for your X3D Player
Opzioni di configurazione per il tuo Player X3D
Thank you!
« Last Edit: June 29, 2015, 04:49:51 PM by margento »
Offline margento
« Reply #57 on: July 12, 2015, 10:23:56 PM »
Is this thread dead?  ;D
