Author Topic: X3 Bubbles Skin by Mede8er  (Read 101094 times)
Offline TifKag
  • X2 Skin Designer
Re: X3 Bubbles Skin by Mede8er
« Reply #15 on: July 02, 2014, 05:36:47 PM »
Done - http://www.mede8erforum.com/index.php/topic,14640.0.html
Great......Thank you  8), now only hoping for the dutch "Relax" Skin for the X2
Offline rwttm001
« Reply #16 on: November 25, 2014, 02:44:18 PM »
Hi all,
New to the Mede8er and found myself longing for something a little more visually appealing than the default UI, I've settled on this for now however (as always with these things) there are a few issues that I'd really appreciate if they could be fixed.
The Media Library sub text is gramatically wrong: 'Navigate all you' should read 'Navigate all your'.
Quite a lot of the capitalisation of the sub texts is questionable.
In Favourites and movie wall, the title of the focused item is in yellow , can this be changed to white as per the rest of the supporting text?
Thanks for listening!
Offline Nine-eleven
« Reply #17 on: December 11, 2014, 10:03:14 PM »
I like the lay-out (the horizontal buttons) and the background from the night_sky skin, can you tell me where I can find it ??
Examples
source image - http://www.mede8er.org/skin_pack_downloads/X3/night_sky.jpg
I couldn't find the sportscar of my dreams. So I build it myself.
Ferdinand Porsche
Offline adamforeman
Re:
« Reply #18 on: December 28, 2014, 01:10:22 PM »
I can't get the new scraper C skin to work with this theme. I've copied the file to this theme folder and set to skin, yet doesn't change the scraper skin. What do you need to do to get both to work?
« Reply #19 on: December 28, 2014, 01:20:25 PM »
If you using an existing 'Skin' then you must just copy the 'scraper' folder including its content into 'Skin' folder.
Offline adamforeman
« Reply #20 on: December 28, 2014, 04:54:03 PM »
Cheers, now working. Perhaps adding the above description to the installation notes would be a great idea. I know some people don't use skins and use the built in one, however, where I got stuck was I was using an external skin and the scraper wasn't working.
Thanks again.
« Reply #21 on: December 28, 2014, 05:12:59 PM »
Good point and will add this
Offline Monaco
« Reply #22 on: December 28, 2014, 06:51:55 PM »
hi , how to change the language of my country ,,Lithuanija.. only : Deskop -Browse media - youtube-internet apps -setup options ; am can translate ; Who will help me ?????
Offline adamforeman
« Reply #23 on: December 28, 2014, 07:56:21 PM »
DO the same as the previous guy did for French
So with need the Lithuanian for:
FAVOURITES
MEDIA LIBRARY
YOUTUBE
INTERNET
SETUP
Then the text underneath each ie under Favourites: "Favourite shortcuts to JukeBoxes, Movies, Music and TV Series"
Once done, Mede8er1 can create a Lithuanian version for you,
Offline dadaii
« Reply #24 on: January 03, 2015, 09:52:18 PM »
 Could you do it for hebrew - because the hebrew here is reversed  - in hebrew we write from right to  left . I give you translations:
FAVOURITES -->  מועדפים
MEDIA LIBRARY  -->  ספריית מדיה
YOUTUBE  -->  YOUTUBE
INTERNET  -->  אינטרנט
SETUP  -->  הגדרות
thanks!!:))
« Reply #25 on: January 04, 2015, 06:57:25 AM »
Offline daltimor
« Reply #26 on: January 12, 2015, 04:38:33 PM »
Thank you well done !!!
« Reply #27 on: January 12, 2015, 04:49:01 PM »
New update as we found a small issue with background image
http://www.mede8er.org/skin_pack_downloads/X3/X3D_Bubbles_Skin_Hebrew_V3.zip
Offline intentus
« Reply #28 on: January 14, 2015, 05:10:51 AM »
I luv this skin :-* :D
During my first making of a skin, I reworked my background to match this skin too (hopefully).
http://www.mede8erforum.com/index.php/topic,15732.0.html
Cheers  :)
Currently happy owner of the following gear...
    MED800X3D + 3 TB WD RED WD30EFRX
    USB 3.0 A-B cable (3 meter)
    ICIDU Express Card USB 3.0 Adapter (AI-707936)
    Pioneer BDR-XD05 (USB 3.0 Blu-ray Writer)
    Panasonic TX-P50VT60Y (TV)
    Yamaha RX-V775 (AVR)
    Dell Precision M4500 (Laptop: 8 GB RAM, Crucial 256 GB mSATA SSD + Samsung 120 GB SSD)
    Dune HD B1
    Popcorn Hour A-400 (died on me!)
Offline Nhokas
« Reply #29 on: January 19, 2015, 11:17:49 PM »
Hi there:
The English EU link for download is not working...
Can i ask you the Portuguese version?
FAVOURITES - FAVORITOS
MEDIA LIBRARY - BIBLIOTECA
YOUTUBE - YOUTUBE
INTERNET - INTERNET
SETUP - CONFIGURA«¬O
Thankyou
