Author Topic: X3 Bubbles Skin by Mede8er  (Read 101093 times)
« on: June 14, 2014, 06:33:31 PM »
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download X3 Bubbles EU - ENG by Mede8er - updated V2
Download X3 Bubbles USA by Mede8er - updated V3
Download X3 Bubbles USA Type2 - by Mede8er - update V3
Download X3 Bubbles USA Type3 by Mede8er - update V3
Download X3 Bubbles Dutch by Mede8er -update V2
Download X3 Bubbles Hebrew by Mede8er - update V3
Download X3 Bubbles French by Mede8er - updated V3
Download X3 Bubbles German by Mede8er -update V2
Download X3 Bubbles Korean by Mede8er - updated V2
Download X3 Bubbles Hungarian by Mede8er - updated V1
Download X3 Bubbles Portuguese by Mede8er
Download X3 Bubbles Danish by Mede8er
If you would like this skin in your local Language then please provide the translation
FAVOURITES
MEDIA LIBRARY
YOUTUBE
INTERNET
SETUP
Favourite shortcuts to JukeBoxes, Movies, Music and TV Series...
Navigate all you Local and Network Media via Samba, NFS and UPnP...
Search and Stream YouTube Videos and setup YouTube pair functionality...
Browse the Internet, Check the Weather, Play Internet Radio, IPTV & RSS Streams...
Configuration Setup options for your X3D Player
You can customize the skin by replacing the Home Page Background  image 'BG_LAYER1.jpg' with any jpg image 1280x 720 pixels or by using the 'Set to Background' option - Remember to reboot the X3D for the new background image to show.
Examples
source image - http://www.mede8er.org/skin_pack_downloads/X3/night_sky.jpg
« Last Edit: February 08, 2015, 01:44:15 PM by Mede8er1 »
jsmiddleton4
  • Guest
Re: X3 Bubbles Skin by Mede8er
« Reply #1 on: June 17, 2014, 03:51:56 PM »
I like this skin pack as well as the button one.  Why?  Because with this one you can change the background image and not mess up the menu selections.  In other words very customizable.
Just one thing.
The Youtube selection, when picking it the ( 8 ) image at the top moves to the left.  The rest stay anchored in the same place.  IF I knew how to adjust the image location I would.  I tried.  But I messed up the transparency aspect.
Is there a way to move the ( 8 ) image for the Youtube menu choice to the right a little and if so how do I do so?
« Reply #2 on: June 17, 2014, 04:01:27 PM »
I have tested the EU and USA one and cannot see this E8E movement on selecting Youtube. Can you download it again and see if you still get this problem.
jsmiddleton4
  • Guest
« Reply #3 on: June 18, 2014, 03:52:16 AM »
Yep.
jsmiddleton4
  • Guest
« Reply #4 on: June 18, 2014, 03:47:24 PM »
Re installed from fresh download.  Everything is fine now.  Not sure what happened before.
Offline marinero
« Reply #5 on: June 20, 2014, 04:46:34 PM »
i just received my 1000x3 today and i find this skin really great!!!! could you do it for french; i give you translations:
FAVOURITES -->  FAVORIS
MEDIA LIBRARY  -->  MEDIATHEQUE
YOUTUBE  -->  YOUTUBE
INTERNET  -->  INTERNET
SETUP  -->  CONFIGURATION
thanks if you can do it (even if you can't!!! ;D ;D)
« Reply #6 on: June 20, 2014, 07:17:43 PM »
X3 Bubbles French added  ;D
Offline marinero
« Reply #7 on: June 20, 2014, 07:56:13 PM »
super!!! thank you....... ;D ;D
jsmiddleton4
  • Guest
« Reply #8 on: June 20, 2014, 10:46:08 PM »
Shouldn't that have been "merci"?
Offline inikad
« Reply #9 on: June 27, 2014, 04:10:11 PM »
To complete the french translation:
- Favorite shortcuts to Jukeboxes, Movies, Music and TV Series... : Raccourcis favoris pour vos Jukebox, Films, Musique et Séries TV...
- Browse the Internet, Check the Weather, Play Internet Radio, IPTV & RSS Streams... : Naviguer sur Internet, Vérifier la Météo, Écouter des Radios Internet, IPTV & Flux RSS...
- Navigate all you (I suppose that is "your"?) Local and Network Media via Samba, NFS and UPnP... :  Parcourir vos Médias locaux ou en réseau via Samba, NFS et UPnP...
- Configuration Setup options for your X3D Player... : Options de Configuration de votre Lecteur Multimédia X3D...
- Search and Stream Youtube Videos and setup Youtube pair functionality... : Rechercher et Diffuser des Vidéos. Configurer l'association de vos appareils à YouTube...
« Last Edit: July 01, 2014, 05:35:20 PM by inikad »
Offline hdmkv
« Reply #10 on: June 30, 2014, 09:31:54 PM »
Found my new skin... thanks.
Firmware: Always Latest Beta
Networked via CAT5e
« Reply #11 on: July 01, 2014, 04:22:01 AM »
X3 Bubbles Skin by Mede8er French - updated
jsmiddleton4
  • Guest
« Reply #12 on: July 01, 2014, 02:39:36 PM »
Yep, this one is a great one.  I'm using the one that is tweaked so the main menu bar displays lower down on the screen.
Offline TifKag
  • X2 Skin Designer
« Reply #13 on: July 01, 2014, 04:37:58 PM »
Any chance on your skins being released for the X2 in dutch  8) 8)
