Author Topic: N36L Microserver through tp link AV600 powerline adapters  (Read 6781 times)
Offline maltmoose
« on: May 29, 2014, 10:28:28 PM »
Thought i'd just provide some feedback on my server and setup that works really well with Mede8er 600 using tp link AV600 powerline adapters.
N36L HP Microserver - (yep there are newer better models) headless, WD 3TB red, 8gb, bluray drive, built in nic.
Ubuntu server 12.04 with webmin web interface, ssh, samba, nfs, ftp, madsonic server etc etc etc
Heres some comparisons using powerline adapters and through cat5e from server to laptop via a router using iperf/jperf
 - reading as follows which is better than expected.
first results are server to laptop via router
bin/iperf.exe -c xxx -P 1 -i 1 -p 5001 -f m -t 10
Client connecting to sol, TCP port 5001
TCP window size: 0.06 MByte (default)
[276] local 192.168.1.107 port 54947 connected with 192.168.1.250 port 5001
[ ID] Interval       Transfer     Bandwidth
[276]  0.0- 1.0 sec  97.1 MBytes   815 Mbits/sec
[276]  1.0- 2.0 sec   100 MBytes   840 Mbits/sec
[276]  2.0- 3.0 sec  95.9 MBytes   804 Mbits/sec
[276]  3.0- 4.0 sec  96.1 MBytes   806 Mbits/sec
[276]  4.0- 5.0 sec   103 MBytes   867 Mbits/sec
[276]  5.0- 6.0 sec   105 MBytes   883 Mbits/sec
[276]  6.0- 7.0 sec  99.2 MBytes   832 Mbits/sec
[276]  7.0- 8.0 sec  99.7 MBytes   836 Mbits/sec
[276]  8.0- 9.0 sec  97.3 MBytes   816 Mbits/sec
[276]  9.0-10.0 sec   108 MBytes   902 Mbits/sec
[276]  0.0-10.0 sec  1002 MBytes   840 Mbits/sec
The depressing bit is when i run this setup through a pair of TP LINK AV600 power line adapters (with gigabit connections) from upstairs to downstairs.
This is what i get through the powerline adapters. (ignore the tplink software its massively optimistic and tells me its running at 250 mbps) its not. Clearly this is running gigabit though as i only get about 11 MBytes/s on 10/100 connections.
[276] local 192.168.1.107 port 53638 connected with 192.168.1.250 port 5001
[276]  0.0- 1.0 sec  16.5 MBytes   139 Mbits/sec
[276]  1.0- 2.0 sec  16.8 MBytes   141 Mbits/sec
[276]  2.0- 3.0 sec  17.0 MBytes   143 Mbits/sec
[276]  3.0- 4.0 sec  17.1 MBytes   143 Mbits/sec
[276]  4.0- 5.0 sec  17.5 MBytes   147 Mbits/sec
[276]  5.0- 6.0 sec  17.2 MBytes   144 Mbits/sec
[276]  6.0- 7.0 sec  17.1 MBytes   144 Mbits/sec
[276]  7.0- 8.0 sec  17.2 MBytes   145 Mbits/sec
[276]  8.0- 9.0 sec  17.4 MBytes   146 Mbits/sec
[276]  9.0-10.0 sec  17.0 MBytes   143 Mbits/sec
[276]  0.0-10.0 sec   171 MBytes   143 Mbits/sec
NOT SO GOOD - this is the reality of powerline adapters for me at least.
The good news is that this is enough to stream makemkv bluray ripped via commandline in the server and shared using NFS without issue.. I have had some stuttering occur using SAMBA, just save yourself the hassle and use NFS.
On the mede8er with NFS i find that setting tcp and auto works best and detects a higher than 32k server setting (whether this makes much difference im not sure)
Anyway i hope this gives people an idea of what they might achieve with a setup like this and if it will work with mede8er, which it does very well.
