Author Topic: Smart Remote Apps using Net Api  (Read 3573 times)
« on: May 20, 2014, 01:37:39 pm »
To  try and avoid confusion Smart Remote Apps where you  browse on the client can  be found in the Net Api section.
http://www.mede8erforum.com/index.php/board,151.0.html
Net Api apps just emulating a remote where you browse using the players GUI can be found here in Community Tools.  Some may  migrate as features are added.
« Last Edit: May 30, 2014, 07:50:52 am by jer1956 »
