Author Topic: MED250X Firmware Update V1.7 -- 15 May 2014 (Latest)  (Read 13857 times)
  • Helpful Contribution Status: +98/-24
« on: May 15, 2014, 06:21:58 pm »
New update for MED250X
Changelog V1.7 - 15May2014
1) Fix: device manager: get fail warning when renaming files more than 5 times in one session on NTFS drive.
If you do not have a unrar program you can download Free program Rarzilla
Download RarZilla Free Unrar
MED250X INTERNATIONAL VERSION
http://www.mede8er.org/Firmware_Final/MED250X/MED250X_V1.7_15May2014.zip
MED250X THAI VERSION
http://www.mede8er.org/Firmware_Final/MED250X/MED250X_V1.7_15May2014_Thai.zip
MED250X CHINESE VERSION
http://www.mede8er.org/Firmware_Final/MED250X/MED250X_V1.7_15May2014_Chinese.zip
UNKNOWN HARDWARE ERROR
If you get a 'UNKNOWN HARDWARE ERROR MESSAGE' then use this firmware
MED250X INTERNATIONAL VERSION V1.65S
https://www.dropbox.com/s/1kbac3i01h7hy5o/MED250X_V1.6S_Europe.zip?dl=0
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button on the Mede8er (not the remote) and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
« Last Edit: August 25, 2015, 04:48:55 am by Mede8er1 »
