Author Topic: V3.0.3 - 12May2014BETA for ME500X2, MED450X2/S, MED400X2/S  (Read 8015 times)
Hi All X2 Users
Download X2 Series - V3.0.3 BETA - 12May2014
http://www.mede8er.org/beta/Firmwares_Beta/X2_Series/X2_Series_V3.0.3_May12_Beta.zip
Changelog  V3.0.3 BETA  - 12May 2014
9. Dev. allow about.jpg EDIT directly after firmware update - old way you had to do a 'Scan' first in order to see the Agreement  Page.
Movie Scraper Skin 'A'
New TV Series Skin
Online Movie Scraper Guide
Online Jukebox+ Guide
JukeBox Plus
JukeBox Plus is actually a dummy JukeBox and can be deleted at any stage without any effect on your source files. Do not set the favourite link to  an actual jukebox as the jukebox+. Using jukebox+ Reset may then delete your media!
If you  find your self in this position, remove/disconnect the host store for the jukebox+, and then perform a Reset Jukebox+. That might require you shutdown first and remove drives, lan  cables etc.   After doing the reset, shutdown again, are reconnect the removed storage.  Favourites will now show "all"  the links including a working jukebox+,  but the Menu  now has the Aggregate Jukebox option to  create the dummy you should have in the first place.  Until you  do  that, Add to Jukebox+ won't appear again. You can then  turn the wrongly used folder back to  a media store.
JukeBox Plus Instructions
Emergency Procedure
« Last Edit: May 12, 2014, 06:46:11 PM by Mede8er1 »
