Author Topic: V3.0.6 - 6May2014 - X3D Series - for MED1000X3D - MED800X3D - MED600X3D  (Read 50623 times)
  • Helpful Contribution Status: +98/-24
We urge you to firstly read the V3 Specific User Manual before just making posts about things not working correctly.
NOTE: All Hard drives must have a unique name for correct functionality with V3 firmware. Connect the Hard Drive to your Windows PC and in My Computer right click the Drive icon and you can give the Hard Drive a name. Remember that each drive must have a unique name example Hard Drive1, Hard Drive2 etc etc
Win7, 8, 8.1 users - Safe Removal is incompatible with the linux NTFS code. Instead use Utility to Eject the Mede8er (or shared external USB drive) - USB Disk Ejector  http://quickandeasysoftware.net/software/usb-disk-ejector
Vanishing files and un-mountable partitions can occur as  a result of using Safe Removal. Those should get fixed by using slave mode, running chkdsk and removing the player using the USB Disk Ejector tool.
V3.0.6_6May2014
1. Fixed - Green screen 3D Top & Bottom and PGS subs
2. Fixed - Button Key mix up on X3D unit buttons (not remote)
3. Improved thick border Subtitles - Its still mirror based and improvement is small but we are trying to stay away from the old way due to the bad Aliasing effect.
To test - Open subtitles menu while a movie is playing and focus on the extreme right menu with 'abc'  - top selection is as it was. Second option is with the improved border.
4. Removed Boot up audio.
5. Changed Home Page YouTube to HTML5 so that users can use USB Keyboard for text input Search
6. Set Auto Standby to 'on' - set time to 2hours
7. Added Setup Option for Movie Scraper A-B - A= long plot length B = old style normal plot length
For the time being this change means the scraper skins no longer work.
8. Updated French Localization
Note: for YouTube exit on USB Keyboard - Ctrl + ',' = Stop
STEP1    IF YOU ALREADY HAVE BOOTLOADER VERSION KIIE.0402.0065 / IAIE 0402.0065 OR USING MED800X3D YOU MUST SKIP STEP1
STEP2
Install V3.0.6 - 6May2014
http://www.mede8er.org/Firmware_Final/MED1000X3D/X3D_Series_V3.0.6_6May2014.zip
X2 Skin for X3D Series
Note: this skin will only work correctly with V3.0.2 or higher
http://www.mede8er.org/skin_pack_downloads/X3/X2_Skin_for_X3_15Dec2013.zip
Red Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Red.zip
Blue Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Blue.zip
Green Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Green.zip
Yellow Focus - http://www.mede8er.org/skin_pack_downloads/X3/X3D_Alternative_Scraper_Skin_V1_TV_Series_Movie_Frame_Skin_Yellow.zip
New TV Series Skin
JukeBox+ Online Guide
Emergency Procedure
Download the latest Mede8er Firmware from www.mede8erforum.com. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X3D. Plug the power jack back in and then hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV.  Do not remove power during the Firmware Update procedure .
« Last Edit: December 20, 2014, 05:44:52 am by Mede8er1 »
