Author Topic: Print folder structure / Windows  (Read 10185 times)
Offline Mimen
  • Newbie and a bit confused
« on: May 04, 2014, 10:50:04 AM »
Is there a way I can print the list of main folders so I can see what movies I have on my Mede8er?
Sent from my SM-N9005 using Tapatalk
Mede8er X3D
Firmware 3.0.4
Laptop Asus Sonic Master
Windows 8
Yamaha RX V373 Amp connected to HMDI cable to the Mede8er
TV LG 42LGF 20 Series connected - HDMI to receiver
Video settings (1080p 50Hz, ,16:9)
- Aspect Ratio (16:9);
- TV Out (I donít know, cant find it)
- Digital Audio (Donít know, cant find it)
Media source:
- Internal HDD Ė (ST300DM001)
Offline Mafalda
Re: Print folder structure / Windows
« Reply #1 on: May 04, 2014, 11:42:53 PM »
Hi Mimen!
1)  Start the Windows Command Prompt (by entering the text "cmd" in the search box);
2)  type "cd desktop" and press Enter;
3)  type dir [space] "Drive:\Folder Path\Folder Name\*." [space] > [space] FoldersList.txt and press enter
              example   DIR "F:\MY VIDEOS\MY MOVIES\*." > FoldersList.txt
4)  on your desktop, you will get a text file (FoldersList.txt) with subfolders list;
5)  now print FoldersList.txt file.
Mafalda
Offline Mimen
« Reply #2 on: May 06, 2014, 01:17:14 PM »
Bliksems, thank you sit but a don't have a BSC in tech speak :-)
I'd rather Google for software able to do that.
Mede8er X3D
Firmware 3.0.4
Windows 8
Media source:
Re:
« Reply #3 on: May 06, 2014, 01:27:55 PM »
Have you tried the program listm8?
You can find it in the community section.
The windows tree command also does a nice job.
Offline captin
« Reply #4 on: May 06, 2014, 04:33:00 PM »
I use a program called Total Commander. It's free.
To print a list of folders (or files)
Browse to your hard drive (location of the folders you want to print)
highlight them all, go up to the menu and click on "mark" then click on "copy selected names to clipboard" or "copy selected names with path to clipboard"
open notepad and paste in the copied names and print.
This program is also THE BEST program for moving, deleting, renaming, viewing all files of any type. Plus a thousand other things.
Way better than windows explorer, with side by side windows for copying, comparing files or folders.
Offline Mimen
Re:
« Reply #5 on: May 17, 2014, 02:38:37 AM »
Thanks guys for the help. I bought myself a personal laptop today as we can not use any non approved software on our work computers. Now that real fun starts.
Mede8er X3D
Firmware 3.0.4
Windows 8
Media source:
Offline puschpull
« Reply #6 on: May 17, 2014, 06:18:58 AM »
Excellent free SW for Directory Printing (or Listing, save to txt file ...) is Karen's Directory Printer
http://www.karenware.com/powertools/ptdirprn.asp
Offline Mimen
« Reply #7 on: May 18, 2014, 06:32:45 PM »
Thanks puschpull,
Karens Directory Printer is EXACTLY what Im looking for!! Awesome, I an now print the folder names only.
Mede8er X3D
Firmware 3.0.4
Windows 8
Media source:
